Top end swap. 107 to 114.
Old Aug 5, 2024 | 07:27 PM
23StreetGlideSpecial's Avatar
Default Top end swap. 107 to 114.
So this may be a stupid question. So I am having the 122 SE stage III put on my stock 114. My bike is a 2023 SG special with 3000 miles. My brother has a 2020 SG standard with I think 15,000 miles. What I am wondering is could I give him the parts from my 114 and he put it on his 107 making his motor a 114. Has anyone done this? Is it even possible? Sorry if it's a dumb question.
Old Aug 5, 2024 | 08:01 PM
pgreer's Avatar
pgreer
The cylinders should be ok but the pistons will not work with a 107 as the stroke is shorter. You could get a set of pistons for the 107 that matches the bore of the 114 cylinders, but there is no guarantee that the new pistons will be the same size as the original ones, meaning they might not fits the existing cylinder bore correctly. So if you go thet route, get an oversized set of pistons ad have the cylinder bored and fitted with the over sized pistons.
Paul
Old Aug 6, 2024 | 04:51 AM
Slingshot383's Avatar
Slingshot383
It would be quite and overbore to make the 107 into a 114 just by boring the jugs and using oversized pistons. The motor would have more high rpm performance than a stock 114, but not the low end torque of a stock 114 as the stroke is shorter.
Old Aug 6, 2024 | 07:27 AM
Fireball Jack's Avatar
Fireball Jack
Will not work.
Old Aug 6, 2024 | 07:40 AM
rigidthumper's Avatar
rigidthumper
107= 4 3/8" stroke x 3.937" bore @ 10:1 (good)
114= 4 1/2" stroke x 4.016" bore @ 10.5:1 (better)
If you used the 114 cylinders and pistons on a 107 engine, you would end up with a low compression 110.84" (111) powerplant.
111= 4 3/8" stroke x 4.016" bore @ 8.7:1 (slug)
Old Aug 6, 2024 | 10:14 AM
Max Headflow's Avatar
Max Headflow
Stroke has nothing to do with TQ,, Displacement does..
Old Aug 6, 2024 | 10:18 AM
Max Headflow
I guess you could trim 1/16 inch off the cylinders... Personally, I'd use the cylinders to bore for bigger pistons.. It makes the engine build quicker..
Old Aug 6, 2024 | 10:31 AM
evildiesel's Avatar
evildiesel
what do you think stroke gives you..
Old Aug 6, 2024 | 11:07 AM
Max Headflow
So which has more tq? A long stoke 114 ci motor say 4.015 x 4.5 or 4.25 x 4. bore and stroke. Displacement is essentially the same..
Old Aug 6, 2024 | 11:28 AM
HD_Roadtripper's Avatar
HD_Roadtripper
6th Gear
Many factors play into how an engine will perform when it comes to HP and Torque, but I'd say piston stroke is heavily related to torque.
Think about it like this, stroke is determined by the crank offset (crank centerline to connecting rod position). Larger offset will have a larger rotational stroke.
Now think about this offset like a wrench. A longer wrench (or stroke as it relates to engines) will apply more torque to the working end than if you used a shorter wrench, given the same input force to each.
A shorter wrench can be spun more quickly due to having a smaller radius (RPM), but torque is reduced.
Just my opinion....
