Ride Planner
You can download a map to your computer to use for BaseCamp which does not require a GPS connected to your PC.
If you load a route with more than 9 waypoints when you hit your 9th waypoint the GPS announces that you have arrived at your destination and thats it. It doesn't look at the route further than that. The GPS does not complain if you load a route that has greater than 9 waypoints, it will load it up like any other route.
I don't know why HD is taking so long to create an update to the software to eliminate that waypoint fiasco. It shouldn't take that much of a code change to make that happen. If you use the "Record" option to remember your route as you are riding it will quickly use up 9 waypoints, hence will not be usable at a later date when you would like to use that saved route.
I immediately called garmin and asked the question to which i already had the answer to. The gps on the 2014 6.5 infotainment system is not garmin, big surprise.
So how am i as customer suppose to know how to operate the system when harley does not even know what system they installed.
Has anyone had any success with ride planner and routing?????????? If so what is your secret.
I have created over 60 routes using ride planner. It does not have all the bells and whistle base camp has. Works great for me. I also use base camp a lot.
RIDE PLANNER is really basic to get you going
BASECAMP is an utter PIA to use
MAPSOURCE is good and easy to to use but now outdated (what was Garmin thinking replacing that with the CRAP that is BASECAMP???)
AND WHAT WAS H-D DOING ABANDONING GARMIN AND GOING WITH I-GO??? probably saving $20 per unit
I do not use the feature that brings up a window called the Drag and Drop for the Start and Destination. Instead I click on File then select New List, then I get the map ready and zoomed in where I am going to start my route.
1) At the top of the map there are some buttons and one of them is a 90 degree bent line with three squares on it. Click that button and that starts the process of creating your route. Now click on the map where you want to start your trip. After you click on that spot on the map you will see that when you move the mouse there is a line ready to create your route.
2) Now start to move your mouse and to force the program to take your roads at some point you will have to click on a road say right after a turn and that will drop a waypoint, and you will see a purple highlighted line which is your route. If you find that you clicked too far away on the map and the program took some roads that you didn't want to take, go up to the top and click on Edit then Undo, which will take you back to the last waypoint. So you might have to click on a road sooner to make the map take the roads you want to use. If you need to zoom out or in on the map use the scroll button on the mouse, if you need to move the map use the arrow buttons to move the map up, down,right or left.
3) Once you have finished your route move your mouse to the button on the top of the map and click the box that has a hand. Once you click on that hand it stops the process of creating a route. If you click the hand you are no longer in the create route mode.
4) on the left side hand side of the screen on the bottom half you will see your route listed and will have some weird name using addresses and street names. If you right click that name you will see options, select Get Info and a small window will open up. That is your route, and if you notice near the top of that window is that weird route name and a small box that is checked - Autoname. Uncheck that box and now you can name your route to something more meaningful to you. Also another good thing I just learned is all your waypoints are listed there, if you right click any of the waypoints that are not your starting or ending points you can select Do Not Alert on Arrival which then makes that into just a shaping point. If you dont do that the GPS will tell you for instance that the destination is two miles away, then when you finally reach that waypoint then it says you have arrived at your waypoint or destination, then after that will alert you at the next waypoint and so on which is annoying. Close that small window.
5) On the top left hand side where it shows your route as "New List" you can right click that and rename that to a more meaningful name as well.
6)insert a USB drive into your PC, highlight the route name on the lower left, then go up to the top menu and select TRANSFER then SEND to device. the route will then be copied to your USB drive and then you can use that to load the route to the GPS on the bike.
Hope i got all that correct
And we are still bound by the 9 waypoint/shaping points per route so hopefully you were able to make your route in under 9 waypoints.
So for me i will go with base camp, I need to learn it anyhow since i have a topo held gps to use on search and rescue missions.
I created a word document out of the tutorial and saved it on my computer for easy ref.
Thanks again.
