Cooling System Recall
Old Mar 13, 2014 | 12:08 PM
mgibson61611's Avatar
mgibson61611
Originally Posted by IUOE ROB
Didn't know this, great bit of info, thanks! Why do you think they did this, maybe as someone mentioned, to bleed away some of the heat and prevent "boiling" after shutdown? Does anyone do this when they park? And does the ignition have to be in the run position? Thanks again!
It's in the manual (owners and service manual, if I recall) and part of the process to purge air from the system after a refill. Cheers
Old Mar 13, 2014 | 12:20 PM
Ghostrider1967's Avatar
Ghostrider1967
Out of the touring models 2014 electrical diagnostic manual. The twin cooled bikes have a ECT engine coolant temperature sensor located at the bottom of the left radiator. It's a thermistor that measures resistance based on temperature. As resistance varies so does the voltage back to the ECM. The ECM monitors this voltage to determine when to start the cooling fans. I guess that's why it's hit or miss based on temperatures, when the bike is shut off.
londo-cat
2014-2024 Touring Models
221
May 26, 2023 01:55 AM
stro1965
13
Oct 3, 2016 11:11 PM
gs34doc
13
Apr 17, 2015 04:39 PM
Afdharley
Dec 8, 2014 03:27 PM
