Com headset
Old Mar 19, 2014 | 12:30 AM
redeye93's Avatar
redeye93
Pic if you would please jcapps. Curious to see what yours looks like. Got the cable today and tried on the headphones. Haven't made my decision yet on headset. It's definitely for only long trips (more than a couple hours). I'm going to check out the IMC headset and I like the idea of the throat mic seeing as I wear a half helmet a majority of the time. I think the boom would be hard to hear just out in the open like that. Thanks for the info all.
Old Mar 19, 2014 | 07:55 AM
jcapps's Avatar
jcapps
[IMG][/IMG]
Here is where I put it, If I change my mind I just need to buy the dash insert. Not a great pic.
Old Mar 19, 2014 | 08:20 PM
redeye93's Avatar
redeye93
I like that alot thanks for the pic jcapps! Think I'm going to go that route.
Old Mar 20, 2014 | 06:28 AM
nuages's Avatar
nuages
Default Com Connector on Street Glide 2014
I went down the 'replacing the tank console' route and used Ultra components. Just looks like an Ultra now with a Harley emblem on the console instead of the Street Glide insignia.
Old Mar 20, 2014 | 08:26 AM
68beep's Avatar
68beep
Originally Posted by jcapps
YOu have to buy the cable and wire it in. Very simple, have to remove outer fairing, seat, tank etc. I drilled out the dash panel and installed it there
Shortened the comm cable and put it in the USB compartment.
https://www.hdforums.com/forum/new-r...eceptacle.html
Old Mar 20, 2014 | 02:26 PM
HarleyManCt's Avatar
HarleyManCt
6th Gear
I use a Sena SMH10 all the time on conference calls. Works great, but you can not sync it to the infotainment system. Have to sync it directly to phone. I am thinking about getting an AKE Bluetooth adapter, and then sync phone to infotainment system, but not interested in being the guinea pig.
Old Mar 20, 2014 | 02:50 PM
NiteOwlNY's Avatar
NiteOwlNY
If you do this before I do please update us how it works. I just have other bills that are taking priority at the moment.
If it works I wonder if I could Y off the tank headset connector and run it into the tour pak.
Old Apr 1, 2014 | 07:35 AM
Wayne Carlton's Avatar
Wayne Carlton
Originally Posted by rmfischer
I have not use either of those headsets for the phone. But I did pick up a throat mic and no one has a clue I am riding when I talk to them using it. It has a mono ear tube but I always have everything come through the speakers but if I remember correctly you can set it to have the phone come through the headset and not the speakers.
this I similar to the one I bought
http://www.ebay.com/itm/New-Weather-...942816&vxp=mtr
i bought one only problem is its two small for my neck it only goes up to a 15" neck I have a 18"
Any one know of a good throut mik that will work with larger necks?
Old Apr 1, 2014 | 07:40 AM
rmfischer's Avatar
rmfischer
The one I bought is snug on my neck. I always thought it should be bigger but I didn't see anywhere that said anything about a size for them. It works fine as is but could be a little bigger. If I find any that mention larger sizes I will let you know. Please let me know if you find any.
Old Apr 1, 2014 | 08:03 AM
Wayne Carlton
For me its not to snug just doesent reach far enough around my neck to pick up my vocal cords well enough.I found the size after I bought it lucky for me a friend rode with me this week end and it fit him great so He bought it from me, I will keep looking for a larger one and post if I find one.
