Saddle Bag Mounts
Old May 8, 2014 | 10:05 PM
Mountain Cruiser's Avatar
Mountain Cruiser
Default Saddle Bag Mounts
You guys ever have the upper pins that hold the saddle bags in place come loose? I have found them laying in the saddle bag a couple of times and have now tie wrapped them in place so that they can not work loose from vibration.
Old May 8, 2014 | 10:29 PM
twig's Avatar
twig
As a matter of fact mine came loose yesterday while out for a ride but I'm sure it was my fault because I had the bags off to clean behind them, I had trouble getting one pin to lock and that's the one that came loose.
Old May 8, 2014 | 10:35 PM
Liquidoxygen's Avatar
Liquidoxygen
Had one of mine fall out once as well. I just slid the bag forward as much as I could and still be able to put the pin in. It puts a little force against the pin and it's been perfect since.
Old May 8, 2014 | 10:48 PM
spr0k3t's Avatar
spr0k3t
Had one pin fall out once. Replaced the pins completely with threaded bolts and loctite.
Old May 8, 2014 | 11:05 PM
offthewall's Avatar
offthewall
The whole pin mounting system sucks but if you get them in correctly, they will not fall out. Don't force the pin in. When positioned correctly, a simple 1/4 turn will lock it in place. If it takes more than that, keep repositioning it until it easily locks in place. Never bang it in.
Mountain Cruiser
That seems like a good idea. I think I will do that.
Old May 9, 2014 | 09:00 AM
Mountain Cruiser
I found this online: http://brukus.com/cgi-bin/p/awtp-pro...rts&item=35502
It seems like a better mounting pin, with some blue loctite it should be good to go.
Old May 9, 2014 | 09:10 AM
sixguns's Avatar
sixguns
When Im out riding the High Desert with my OL on the back, passing a line of autos and looking down at the speedo, its doing 100+. Last thing I need is a bag flying off. I put Brukus screws on and no more worries. I never had one of the MOCO retainers come loose but they never gave me a warm fuzzy feeling like the Brukus does.
Old May 9, 2014 | 09:43 AM
SafetyMan's Avatar
SafetyMan
I always used these, with a couple of stainless fender washers and a few rubber fender washers.
Problem now is with the new system, I can't hold them in place whilst I put the pin in.
Proper length, of course...
But I will find a way... I've been a Frac'er for 19 years, I'll make it happen, by God, and I'll put up pics when I do.
Old May 9, 2014 | 12:21 PM
fijf4357's Avatar
fijf4357
I removed the stock pins/clips and took a trip to Ace Hardware and added new hex head screws/clips. all for around $7. no chance to fall out or stolen (quickly)
