CANBUS Question
Old Jul 1, 2014 | 04:23 PM
Hammz's Avatar
Hammz
Originally Posted by p51bombay
Picking up a 14 UC next weekend, I was going to order a Dyna beep beep horn from the new FXDL to remove the cowbell and relocate the new horn to the frame down tubes but the keep saying no, no, no - you can't change the wiring at all. Is this correct? My plan was to simply extend the wires going to the horn and plug into the new horn at the new location.......still two wire connection right? Will that cause a problem? Can I still use regular stranded automotive wire? Not really up on what you can and cant do with the canbus system.
Maybe you should just let your dealer deal with it? That way you won't have to take responsibility if it doesn't work out the way you want?
Gbishop303
Apr 12, 2017 06:09 PM
phamtom
Jul 8, 2014 01:00 PM
Lgossett
Feb 22, 2012 05:50 PM
nivensid
Feb 21, 2012 12:42 PM
jsbridgew
May 26, 2009 09:11 AM
