Slight knock?
Old May 31, 2014 | 06:50 PM
Liquidoxygen's Avatar
Liquidoxygen
Default Slight knock?
When I am on the highway and i do short bursts of on and off the throttle I can hear a slight knock from somewhere low on the engine. its only once for each motion...(throttle on..knock...throttle off...knock) its like something hitting metal to metal. Any ideas?
Old May 31, 2014 | 06:54 PM
xhere's Avatar
xhere
Might check your motor mounts and fasteners and make sure all is tight. Maybe something shifting when torquing up.
Old May 31, 2014 | 07:03 PM
Harttoo's Avatar
Harttoo
Are You sure it's not primary chain clunk?
Old May 31, 2014 | 07:18 PM
TexasMotorcycleRider's Avatar
Same here, just figured it was drivetrane play.
Old May 31, 2014 | 09:38 PM
PA1195's Avatar
PA1195
There's normal play in the:
Rear end...there's a rubber cushion between the wheel and drive pulley that absorbs shock.
Transmission...some bang back and forth due to gear lash/clearances.
Primary chain...if not tight, can provide some play between the compensator drive sprocket and the clutch/driven sprocket.
Compensator sprocket...it can rotate as designed to cushion shocks between the crankshaft and the clutch.
All can make noise like a knock. So can an intermittent ping before the ECM retards the spark if detected, but that's another topic.
Old May 31, 2014 | 09:51 PM
Liquidoxygen
Motor mounts and fasteners all look good. It does kinda sound like it could be chain slap but it sounds a little more solid and maybe not from that area. As far as the comment about it being normal. I don't know man none of my other Harley's do it.
Old May 31, 2014 | 10:36 PM
PA1195's Avatar
PA1195
Try this. Power on, power off. Try to tighten the top of the primary chain and loosen the bottom run via power on, then off. The auto adjuster should take up the chain tension after a couple of these when the bottom goes slack if that's the problem. I can hear the transmission gear slack as a light metallic clank in my '14 Road King with just light power on-off.
Old Jun 2, 2014 | 03:36 PM
I am referring to the gear slap....if I am in 5th gear running 40-50 and get in the throttle then let out I can hear the play in the gears. It was the same on the Honda VTX with under 5000 miles on it so doesn't seem to be anything new to the Harley. Maybe not the same noise the OP is hearing but I would think that it's normal considering the industrial nature of the engineering in the transmission.
RinTin
Milwaukee Eight (M8)
Jul 31, 2017 08:22 AM
2010IRON883
May 5, 2014 11:34 AM
outlawrider
Sep 6, 2010 07:55 PM
sprint12
Jun 15, 2009 03:02 PM
creekhed1
Apr 19, 2009 06:02 PM
