DTC access
Old Jun 12, 2014 | 09:06 AM
oakmossy's Avatar
oakmossy
Default DTC access
How can you check the DTC's on a rushmore?
Old Jun 12, 2014 | 09:33 AM
dwludwi's Avatar
dwludwi
From Harley:
The new infotainment systems incorporate expanded diagnostic capabilities.
To access the diagnostic menus, hold the power button in while turning the ignition switch to the accessory position until the warning screen appears.
Then release the button and click on accept.
The Service menu will be displayed. The up and down arrows on the right are used to scroll through the menu options.
You can use the five way switch on the right hand control or the faceplate controls to navigate.
To view diagnostic trouble codes, highlight and select DTCs on the display.
A listing of all current and historic codes logged by the radio will be displayed. Use the arrow icons to scroll through listings.
Selecting the “i” button will change the display so that it lists a description of the code rather than the code number.
Selecting clear all DTCs will clear the codes.
Old Jun 12, 2014 | 09:38 AM
DPete's Avatar
DPete
I held down the speedo select button and turned the ign to run, codes or lack of came up on the speedo like the older bikes
Old Jun 13, 2014 | 09:25 AM
oakmossy's Avatar
oakmossy
great thanks
Old Aug 5, 2014 | 06:52 PM
YPD485's Avatar
YPD485
Mine said no DTC's in the 6.5 info display.
alrosse
2014-2024 Touring Models
Jun 24, 2015 09:27 PM
rossn2
32
Jan 17, 2013 09:00 PM
steelerdude1
Jul 22, 2012 04:16 PM
rgoolsby
Sep 26, 2011 07:18 PM
Gonzy
Jun 21, 2011 03:18 PM
