Shifter problem
Old Jul 21, 2014 | 09:43 AM
skybox ed's Avatar
skybox ed
Question Shifter problem
Has anyone had the problem where the shifter shaft has stripped out? headed out to work and when I went to hit 2nd, the toe shift lever was on the floor board. luckily I was in driveway and was able to pull back into garage. found the front arm that attaches to the shaft on the back side of the primary to the shift linkage rod had stripped out. I was able to rotate the shaft and get some new splines to grab between the 2. 10k service Wednesday and hoping dealer will replace.
Old Jul 21, 2014 | 09:49 AM
Yukon42's Avatar
Yukon42
I have heard of that problem in years past but never experienced it myself. I always remove the heel shifter first thing.
Old Jul 21, 2014 | 10:36 AM
lionsm13's Avatar
lionsm13
There is quite a few that have actually. It is a weak point.
What are you implying?
Old Jul 21, 2014 | 11:07 AM
Harttoo's Avatar
Harttoo
Happened to Me on 2012 Limited at about 25000 miles.Fixed under warranty.
Old Jul 21, 2014 | 12:16 PM
SafetyMan's Avatar
SafetyMan
...the front arm that attaches to the shaft on the back side of the primary to the shift linkage rod...
I'm confused.
Which one stripped?
The arm that shares the spline shaft with the shift levers?
or
The arm that is on the backside of the primary?
I have heard of that problem in years past but never experienced it myself. I have an Amber Whiskey and Vivid Black bike.
Old Jul 21, 2014 | 01:05 PM
Yukon42's Avatar
Yukon42
I imply nothing. Did my comment offend you in some way or what?
Old Jul 21, 2014 | 01:54 PM
lionsm13's Avatar
lionsm13
Then what does Originally Posted by you Yukon42
"I always remove the heel shifter first thing" have to do with Op's question of" Has anyone had the problem where the shifter shaft has stripped out?
The way it is posted or rather "implied" from your comment is that there is a correlation?
Did I read this wrong and were you offended by my question to you?
Old Jul 21, 2014 | 05:11 PM
jake40ma's Avatar
jake40ma
i imply stupid chit
Old Jul 21, 2014 | 06:19 PM
Yukon42's Avatar
Yukon42
Well I'll tell you what Mr. Forum Policeman, perhaps you can get your panties unwound if you would take your neurosis and find something else to get wound up about. Maybe you should go actually RIDE your bike instead of posting on the forum so much before your neurosis becomes a psychosis. Be a lot cheaper than finding a psycho therapist to help you deal with your problem.
Old Jul 21, 2014 | 07:05 PM
skybox ed's Avatar
skybox ed
the arm that shares the shift lever and splined shaft. called dealer this am to make sure he'd have the part and he said they did and would swap out shaft and arm no problem.
