2018+ Softail Models Breakout
New derby cover
Old Jan 31, 2019 | 08:45 PM
Superdog3:16's Avatar
Superdog3:16
Default New derby cover
Hi guys. Put a new dark customs derby cover on today. Bike was cold cold here in Ohio. When I got it open, I noticed the oil was waaaaay down there, just barely visible. I remember on my others, it was close to running out or at the bottom of the clutch? Should I add some? Bike only got less than 200 on it, won't really ride til spring. Owners manual says check with warm engine, but that's a big diff to make up? Thanx!
Old Jan 31, 2019 | 08:48 PM
Superdog3:16
Old Jan 31, 2019 | 10:08 PM
Buster217's Avatar
Buster217
On my 2011 FB the primary oil level was close to the bottom of the opening, as was the bottom of the clutch. On my 2018 Heritage the bottom of the clutch and proper oil level is well below the opening. It threw me off a bit the first time I opened it because the picture in the 2018 manual looks like the old configuration on my 2011 bike. At first I thought it was under filled because it appeared to be much lower than it was on my FB.
Old Feb 1, 2019 | 06:20 AM
FrankEV's Avatar
FrankEV
I also overfilled my primary thinking it was not at the correct level. Go by the recommended ounces per the manual. Will look low.
Old Feb 1, 2019 | 06:28 AM
moose545's Avatar
moose545
Good to know you can change the cover without any spillage at least!
Old Feb 1, 2019 | 06:44 AM
Scudda's Avatar
Scudda
Did you check while it was on that Jack? I believe it is supposed to check while on the stand
Old Feb 1, 2019 | 08:07 AM
Ludwig von Buzzthoven's Avatar
I went through this when I swapped out the derby cover on my ‘17 Slim a few months back.
First, it’s almost impossible to tell where the level actually is unless you shine a bright light down into the primary case.
Second, the level sits way lower than you think.
This thread might help you:
https://www.hdforums.com/forum/prima...oil-level.html
Old Feb 1, 2019 | 08:21 AM
Superdog3:16
I had it straight up/ level on the jack. I think manual says that, buy I'll look again.
Old Feb 1, 2019 | 08:28 AM
rochman's Avatar
rochman
Default Primary Oil Level
It is my understanding that the bike needs to be straight up or at least leaning to the right , away from the stand , If opened on the stand oil will run out , on Touring models anyway.
Old Feb 1, 2019 | 12:17 PM
Buster217's Avatar
Buster217
Can't speak for all softails but on my Heritage you can remove the cover with it leaning on the stand and oil will not come out but you have to have it upright in order to properly fill/check the level.
