Tab Muffler on Sport Glide
Can anyone comment on the sound, and any decel popping, fueling issues with the Street tuner and no dyno tune?
You can always change the muffler back to stock for service as well, 5 minute job.
Good luck if you need warranty work and you are away from your dealer with your non epa compliant exhaust-muffler.
Non-epa compliant parts will void your warranty.
You might get lucky, you might not....
You already have a sepst to preserve your warranty,
Then you should stick with SE parts.
Otherwise you should get a PV or fp3 which will be way better for fine tuning any after market exhaust-muffler as sepst is not designed for that and will most likely make your bike run too lean.
All i am saying is that if you want to keep your warranty, after market exhaust which is non epa compliant is a gamble And it does not make sense to use a sepst with aftermarket exhaust
Muffler is part of the exhaust.
1. Once you use your non-EPA tuner, you are done - HD can read the ECM and see that you have used a tuner. It's a one-way street. No thanks. Pro Street preserves your warranty.
2. Changing just the muffler is NOT the same as full exhaust, and there is no need to have a full-blown tuner to make it work within the same parameters as stock, i.e. a bit lean for EPA. It also allows me to tune other things like throttle progressiveness.
3. Using aftermarket muffler allows me to get the sound I want, as the cannon is basically as quiet as stock, with just a slightly different sound.
4. I will take the VERY slight chance that my new bike will fail catastrophically enough and far away enough from home to not be able to put the muffler back on vs enjoying the sound I want on daily basis, AND that Harley will not only find out it's an aftermarket muffler, but will ALSO deny the claim based on said muffler.
Once the warranty is up, I'm definitely going PV and stage II with aftermarket cam and full exhaust, but I have two years before that.
