2018+ Softail Models Breakout
Paul Yaffe 6inch monkey sport bar installing help
Old Mar 23, 2019 | 02:12 PM
XXTHESANDMANXX's Avatar
XXTHESANDMANXX
Default Paul Yaffe 6inch monkey sport bar installing help
I have a 2018 low rider ,and I am planning on installing some Paul Yaffe 6 inch monkey sport bars next weekend ,and would like to know if you have to remove the connectors on the ends of the wiring so I can slide them through the bar ,also I will be relocating the signals to the forks, so those are wires that I dont have to run through the bars , any tips are greatly apriciated ,
Old Mar 23, 2019 | 02:17 PM
AJ88V's Avatar
AJ88V
Nice bars. I watched a video for this when I was looking at Street Glides.
Old Mar 23, 2019 | 02:54 PM
XXTHESANDMANXX
https://youtu.be/gUzIju9lRi8
thanks for the video,but he takes the pins off to run the wires I want to know if it is possible to run the wires without taking off the pins(connectors)if I have no choice but to remove the connectors ,then I will,but really dont want to go through all that process . thanks again
Old Mar 23, 2019 | 03:19 PM
yobtaf103's Avatar
yobtaf103
I Fitted my P Yaffe 6" monkey bars without removing the connectors ,on my 18 RGS
Used a length of the bath plug ball chain, feeds thro bar easily under its own weight /gravity
folded chain between the wires & over the connector , lubed all sheath with liquid soap, patience required more so on throttle side
Old Mar 23, 2019 | 05:57 PM
AJ88V's Avatar
AJ88V
Yeah, I watched that video back in November and didn't remember if he pulled the plugs off or not.
But today I relocated the front turn signals on my Low Rider to the forks for a fairing install. Removing the connectors was the only to pull them without pulling all the wires from the bars. To be honest, once you've done one connector, the second one is trivial.
So go ahead and try it without removing the connectors. If you end up needing to remove them, don't worry, it's easy.
Old Mar 23, 2019 | 07:21 PM
XXTHESANDMANXX
thanks going to try it if not I will take them off , just looking at options ,
im just going to have to be patient ,if all else fail and hve to remove the connectors
Bochawa72
Jan 12, 2019 05:38 PM
DJY
Jul 9, 2013 06:04 AM
timvan
Mar 22, 2012 09:40 PM
2006FLST
Apr 5, 2010 09:05 AM
HDF Tech
Jun 25, 2005 06:46 PM
