Fp3
I compared it to the posted FP3 fuel table below:
Green is 1% difference or less. Basically no difference.
Blue is when the FP3 is richer by the percent shown (lower Air Fuel Ratio (AFR) is richer so a negative change percent is richer)
Yellow is when the FP3 is leaner by the percent shown.
One difference to note is the 20 MAP column where the fuel enrichment helps prevent decel popping.
The other is the 80 and 85 MAP columns above 1500 rpm. This takes the engine out of closed loop O2 sensor control and enrichens the mixture at a smaller throttle opening (sooner) than H-D does. When you open the throttle, Manifold Absolute Pressure (MAP) goes up to a max of 100 kPa which is typical atmospheric pressure.
The FP3 advantage comes in tuning non-Harley engine components and non-Harley exhaust. The H-D tuner is limited to tuning H-D Screamin' Eagle Stage Builds or very similar aftermarket parts.
The H-D auto tuning module with wide-band O2 sensors can adapt to a wider range of components. The best situation with any tuner is to have the bike tuned on a Dyno.
Hers with fp3
Mine with dynojet
Hers, even thi I programmed it for no decell pop. Still pops
Mine I dowloaded a map programmed for no decell pop. Does not
So I think that even tho motors may be identified as same, will not respond the same to inputs after market tuners try to provide.
So not all tuners, even when programmed for similar performance tables will not generate similar results.
Hers with fp3
Mine with dynojet
The target command tables like fuel, spark, warm-up etc. are usually never changed. What is gained from dynamometer or road tuning is measured volumetric efficiency (VE) for your engine, cam, intake, and exhaust combination.
The VE table is used to "dial in" the calculated air mass flow through the engine and then, using the Air Fuel Ratio target, the fuel injector command is determined.
A download tune uses typical or estimated values for VE, usually pretty good, sometimes not so good. Hence, the difference between bikes.
When you are cruising around, the engine is in closed loop control and the Oxygen (O2) sensors are used to compute fueling so the bike adapts and VE accuracy is less important. During acceleration transients or heavy engine loading, the ECU switches to open loop and is totally dependant on the VE tables being correct. Open loop is needed because the O2 sensors can not deal with the needed rich fuel mixture or the rapidly changing conditions in the engine. The ECU can do the required calutations fast enough using the VE tables and ignoring the O2 sensors for the moment.
