2018+ Softail Models Breakout
Removing dB reducer really impacts performance?
Old Feb 20, 2021 | 07:14 AM
  #31
OldMike's Avatar
OldMike
Originally Posted by Denno1064
I’m told it does. Will soon find out.
I have a spare Bassani 2-1 exhaust and I've also played around with dB reducers for my S&S Superstreet muffler but never thought to try it with the Bassani, I think it's possible though.
I can tell you the S&S with dB reducer feels responsive and fast right off idle. The Bassani a bit less off idle but has a stronger midrange. The dB reducer in a Bassani is going to be a quieter system for sure.
Old Feb 21, 2021 | 12:22 PM
  #32
PataGrande's Avatar
PataGrande
Ooooh man I got a Superstreet I picked up off the for sale section here, thanks Coopmonte, can't wait to get it on.The parts shopping never ends hahaha
Old Feb 25, 2021 | 05:00 AM
  #33
Denno1064's Avatar
Denno1064
2nd Gear
Listening to the video in this string comparing stock, Bassani as S&S with/without reducer, the Bassani is the loudest. I reckon the reducer still sounds great though and if it works in my Bassani, it might just take some edge off the almost obscenely loud pipe! Good obscene though!!!
Old Feb 25, 2021 | 05:13 PM
  #34
Bowhunter8607's Avatar
Bowhunter8607
The S&S without the dB reducer caused a ton of droning in my ears and seemed quite a bit louder to me when I did the comparison. The Bassani was much more tolerable for my ears. I liked that Bassani but had to get rid of it due to scraping the front header in right hand curves.
I've really been enjoying the S&S though. Especially after installing the S&S touring pipe baffle following OldMike's advice.
Old May 31, 2021 | 04:16 PM
  #35
Jason Kauffman's Avatar
Jason Kauffman
Stage II
Originally Posted by Bowhunter8607
I was this someone. Not sure how much loss there is to show on paper but it is very noticable while riding. Simply remove your dB reducer and you will see what I mean when I said there is a noticable loss of torque and power down low until about 3500 RPM.
With the dB reducer in, the bike is more responsive down low and pulls harder through the low and mid range. I didn't feel a difference in the upper RPM range with and without the dB reducer installed.
The pipe sounds mean as hell without the dB reducer in but it was too much droning for my ears. Plus I like the way it performs with the dB reducer installed. I cut the dB reducer down to increase the volume a bit. It helped a bit and had no noticable effect on the performance.
Mchad had his on a dyno with the full length dB reducer and a dB reducer he cut down in length as I did and the dyno showed a negligible difference between the two. I'll look for that thread and place a link.
Out of curiosity and because I want to cut my db reducer down, did you have to retune the bike afterwards?
Old May 31, 2021 | 06:22 PM
  #36
Bowhunter8607
I ran auto tune on my Power Vision a few sessions afterwards just in case but I'm not sure it was necessary.
Qdog002
Exhaust System Topics
Oct 16, 2019 11:03 PM
WH1_T-type
Feb 27, 2018 01:47 PM
Rickey Lummus
Oct 6, 2016 06:10 PM
MOSTWANTED
Feb 18, 2013 04:00 PM
NYSportster
Apr 3, 2006 03:08 AM
