2018+ Softail Models Breakout
Any kickstand extensions or kickstand blocks?
Old May 4, 2020 | 07:45 PM
nightsterept's Avatar
nightsterept
Default Any kickstand extensions or kickstand blocks?
I installed a +1 longer rear shock on my FXLRS, are there any options for kickstand extensions or kickstand extension blocks?
Old May 5, 2020 | 11:05 AM
Tozco's Avatar
Tozco
Since the jiffy stand mount bolts onto the Softail frame, I just made some spacers and got longer bolts moving the stand to the left which has the affect of making the bike sit more upright.
Old May 5, 2020 | 11:06 AM
nightsterept
Thanks for the reply, much appreciated. Do you have any pics by any chance?
Old May 5, 2020 | 03:51 PM
24v's Avatar
24v
https://www.luckyspeedshop.com/colle...and-lift-block
Old May 5, 2020 | 03:52 PM
24v's Avatar
24v
I extended my own by cutting it and welding a sleeve in the middle adding 1.5".
Old May 6, 2020 | 06:48 AM
nightsterept
Thanks for the replys...much appreciated. Besides from adding an extender block (not desirable) , is there an actual longer jiffy/kickstand available? I do recall this being discussed, but do not recall if an answer was found?
I am curious about adding spacers to the actual kickstand mounting bolts, that seems feasible... Maybe even a 1/2" spacer would make a difference.
Old May 6, 2020 | 06:51 AM
24v's Avatar
24v
I do not believe anyone has posted actual lengths of the stands, but people have posted that the FXFB and FXFBS have a longer stand than the other models. The FXLRS uses the same stand as the FXFB and FXFBS.
This is how I extended mine. Wasn't super difficult.
Old May 6, 2020 | 06:58 AM
nightsterept
​​​​​​Yes, that's the post I was thinking of, from your thread. It seems to make sense that the FXFB and FXFBS would have a longer stand as the shock itself is longer...but I agree, the part numbers are shared.
Old May 6, 2020 | 01:48 PM
AJ88V's Avatar
AJ88V
If you want to look into swapping jiffy stand legs, here's a table I made up from the parts book
The "Description 2" comes from looking up the parts individually online and then shortening the relevant info.
As you see, all the 18+ Softails use the same bracket, so you should be able to just swap the leg itself to get a longer or shorter length.
Old May 6, 2020 | 02:03 PM
nightsterept
Thanks for the table and parts info. So my bike is a FXLRS, according to this I already have the tallest jiffy stand available for the 18+ softails?.... And in that case I'm outta luck on swapping out to a longer stand if I'm reading this correctly.
MMH
Apr 30, 2019 10:48 AM
ghostrider69
Jul 18, 2011 10:51 PM
NuTTSaK
Oct 30, 2010 08:05 AM
transam7969
May 11, 2010 06:47 PM
A-10 KChawg
Apr 30, 2009 11:13 PM
