2018+ Softail Models Breakout
Cable ext for 18+ Fatboy models
Old Aug 26, 2020 | 11:43 AM
andres.0321@hotmail.com's Avatar
Default Cable ext for 18+ Fatboy models
So I just looked up the Handlebar installation requirements from Harley. I have the part numbers based on 1) 12 Fat Chiseled bar and 2) 12 Fat ape bar. This is just OEM look cables. You only need to replace upper cables.
For 1) you would need the following parts:
Upper Clutch cable-37200386 length 45"
Upper Brake cable-41800657 length 29" 170 degree banjo
Brake adaptor- 41600260
Throtle cable ext-69201804 length 18"
Switch ext- 69200034 length 10"
Turn ext-69201795 length 8"
For 2) you need the following parts:
Upper Clutch cable- 37200384 length 43"
Upper Brake cable- 41800710 length 31" 170 degree banjo
Brake adapter- 41600260
Throtle ext- 6920184 length 18"
Switch ext- 69201794 length 18"
Turn ext- 69201796 length 16"
Hope this helps
stbobshadow
Apr 1, 2016 03:17 PM
edizzle
Apr 13, 2014 05:52 PM
fordaith
Aug 14, 2012 11:02 PM
CV350
Jul 18, 2011 09:29 AM
rattboy fatboy02
Feb 17, 2011 06:06 AM
