2018+ Softail Models Breakout
Adjusting the pre-load
Old Sep 21, 2020 | 10:29 AM
VtwinLust's Avatar
VtwinLust
Default Adjusting the pre-load
Having to take the seat off and adjust the pre-load of the rear shock every time a passenger hops on might occasionally be inconvenient. If you sometimes choose not to do this, how bad is it? And if you're not going to adjust it, is it better to leave the shock set just for the rider, or for the rider + passenger?
Old Sep 21, 2020 | 11:11 AM
Hulkss's Avatar
Hulkss
It's no problem at all. You may notice the bike bottoms out occasionally with a passenger. If so, add preload. If you notice it topping out too much without a passenger, remove some preload.
Old Sep 21, 2020 | 11:18 AM
Uncle G.'s Avatar
Uncle G.
It’s a hell of a lot easier than jacking up the bike and laying in the ground with two wrenches to adjust the preload like you had to do with an Evo or Twin-Cam Softail.
Old Sep 21, 2020 | 02:43 PM
Mart's Avatar
Mart
I run my Slim almost on max preload, at setting 6 of 7. I'm 170lbs + gear. I only ride solo. I no longer bottom out, I don't top out and I believe I can lean more before footboard pegs touch down. This feels the most comfortable and best handling setting for me. When I toured this month, I didn't touch the preload to take the weight of luggage. No problem.
Old Sep 21, 2020 | 03:03 PM
OldMike's Avatar
OldMike
I installed a Fat Bob shock that has a convenient adjuster. I change settings depending on whether I'm using bags and a rack or not.
flyboyron
Aug 1, 2022 06:05 PM
hell hound
May 28, 2020 06:34 AM
1fallenangel
Sep 7, 2015 08:10 AM
greg3131
Mar 5, 2009 12:54 PM
HDF Tech
General Topics/Tech Tips
Aug 8, 2005 04:59 PM
