2018+ Softail Models Breakout
Where Is My Engine Oil Going?
Old Oct 15, 2020 | 01:51 PM
  #61
Tampa Fatboy's Avatar
Tampa Fatboy
Originally Posted by OldMike
Well, now looks like you should probably adjust accordingly.
Why are you responding if you havent changed your fluids?
Those with hands on going thru the same thing, I have no doubt.
The manual is an iffy thing with this M8. I just hope torque values are correct now...*laffs
Old Oct 15, 2020 | 01:53 PM
  #62
OldMike's Avatar
OldMike
I changed my oil twice.
Old Oct 15, 2020 | 01:54 PM
  #63
Tampa Fatboy
right
Old Oct 15, 2020 | 01:58 PM
  #64
OldMike's Avatar
OldMike
right
I do all my own maintenance correctly, I did the first oil change at 100 miles.
Old Oct 15, 2020 | 02:04 PM
  #65
Tampa Fatboy
Interesting, but you didnt chime in with your final fluid capacity when I specified how the manual said to do it and what I ended up with.
Now I'm curious, why not? What was your end result?
Old Oct 15, 2020 | 02:08 PM
  #66
OldMike's Avatar
OldMike
I start out with 4 quarts and ended up adding another 1/2 quart, went for a ride and the level was 1/2 way from add. That's how I left it. Be careful with the manual, going to full capacities.
Old Oct 15, 2020 | 02:18 PM
  #67
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Best advice, change the oil yourself so you see when and where that oil is on the dipstick.
Start with 4 quarts, run it for a couple of minutes.
Start with 4 quarts (maybe even 3-1/2), take it out and ride it for a while, until the system is hot (you`re not going to starve the engine of oil with 3-1/2 quarts in the system).
When you come back from a ride, idle the engine for 2 or 3 minutes (either on jiffy stand or straight up, but do it the same way every time you check the level).
Check oil on jiffy stand or straight up, again, establish a process and stay with it.
Once you have determined how much your bike takes, just write it down in your toolbox, next time you change the oil you know how much to just dump in and go.
Old Oct 15, 2020 | 02:20 PM
  #68
Tampa Fatboy
Fair enough, I like your answer. That was straight up.
Manual is very wrong.
Tomorrow is primary fluid/clutch pak adjustment. I want to see just how off their 36 oz recommendation is.
Old Oct 15, 2020 | 02:34 PM
  #69
GrenV's Avatar
GrenV
I did 4qts then another 1/2 qt to bring it right to middle of the stick.
Old Oct 15, 2020 | 02:43 PM
  #70
Tampa Fatboy
see...you modified the manual instructions as 'Mike' did. Interesting, this is what I'm on about.
Hopefully quite a few reads these posts.
