2018+ Softail Models Breakout
Need advice. Crash Bar install gone wrong
Old Jan 10, 2021 | 02:04 PM
BuddyB's Avatar
BuddyB
Default Need advice. Crash Bar install gone wrong
So it's not the crash bar that went wrong but attempting to take off the last and final bolt I needed to install the thing. Of course with my luck, or maybe it being 2021, that the last bolt strips. It won't grab so I'm looking for ideas on how to get it off. Those bolts all seemed to be super glued until it would finally break. Had to use a breaker bar to get them to break loose. A buddy of mine suggested a manual impact driver. Anyone have experience with this type of situation? Here's a pic
Old Jan 10, 2021 | 02:21 PM
OldMike's Avatar
OldMike
I just did this.
After it stripped:
I used a drift and a heavy hammer to hit the bolt head and flatten it just a bit.
Made sure I had a good T45 Torx bit and hammered it into the bolt.
Applied heat to the frame.
I did use a 1/2 to 3/8" adapter so I could use my larger 1/2" ratchet.
I already bought new allen button head bolts to replace these.
Old Jan 10, 2021 | 02:35 PM
Hulkss's Avatar
Hulkss
Originally Posted by OldMike
I just did this.
After it stripped:
Some heat is the secret. It softens the Loctite compound in the threads.
Old Jan 10, 2021 | 02:51 PM
Lanyu's Avatar
Lanyu
I had the same problem with a couple of bolts when installing my forward controls on my FXLRS
Old Jan 10, 2021 | 02:54 PM
Hoginedgewood's Avatar
Hoginedgewood
Impact is on the top of my listfor this.
Old Jan 10, 2021 | 04:41 PM
470004's Avatar
470004
Heat then an impact driver.
Old Jan 11, 2021 | 05:15 AM
jtodd's Avatar
jtodd
I had one strip once so badly that I bought jbweld and epoxied a nut to it and used a socket on a breaker bar to remove it. Fun times.
that is kinda last resort stuff.
Old Jan 11, 2021 | 05:22 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Check parts list as some screws have a lock patch which is not Loctite.
Old Jan 11, 2021 | 05:30 AM
Bass Player's Avatar
Bass Player
Try a metric that you have to drive in and some heat.
Old Jan 11, 2021 | 05:34 AM
Andy from Sandy
Torx is torx. I don't see a difference depending on the thread cut.
