In my case it was the front brake switch which is a known problem. The FP3, or other tuners I suppose, will read codes for you and tell you, in English, what it is.
Based on what you described, next time it occurs, play with the front brake lever and see it it goes off. That would confirm it is the switch remaining open.
Saturday I got ready to go for a short ride and neither the brake light or tail light worked, put in new, will see how long this lasts. I have never had to change out bulbs like I have on this motorcycle. On my 4th regulator, too. Not seeing any type of sticky brake switch.
If you're changing regulators that's what's blowing your bulbs
No codes they just pop up on the display Don't have any.
Harley changed the regulators under warranty, probably the one on there now was in November. Bulbs have gone at different times than the regulators. But, I am sure it's all related. Never a code.
That sux, whats causing the regulators to go bad be my concern.
Warranty will run out.
Hey you were right I looked on my power vision and there was a hidden fault break switch low ,so I cleared that and the switch has been adjusted to wait and see if the light comes back
