2018+ Softail Models Breakout
Heel / Toe Shifter
Old May 16, 2021 | 02:44 PM
murphy0726's Avatar
murphy0726
Default Heel / Toe Shifter
1st question, since the Heritage Softail Classic is considered a Touring Bike, then why did they remove the heel shifter starting in 2018(?)?
2nd question, how hard is it to add this heel shifter, or should I have the dealership do it?
thanks.
Old May 16, 2021 | 03:01 PM
MikeZ's Avatar
MikeZ
They removed them from all the Touring models. Apparently, most people were removing them, so they decided to ditch it. It's an easy install if you have reasonable mechanical skills, and there are YouTube how-to videos available.
Old May 16, 2021 | 03:15 PM
gonemad's Avatar
gonemad
*deleted due to opening mounth before engaging brain.
Old May 16, 2021 | 03:20 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Are you guys sure the shaft doesnt need replaced with a longer two spline one?
Old May 16, 2021 | 03:21 PM
murphy0726's Avatar
murphy0726
Do you use the same shaft or do you need a "shaft extension" or something like that?
Old May 16, 2021 | 03:22 PM
murphy0726's Avatar
murphy0726
My thoughts exactly.
Old May 16, 2021 | 03:31 PM
Campy Roadie's Avatar
Campy Roadie
I can't speak for the m8 but on a twin cam you're gonna have to pull the outer and inner primary to install that shaft.
Old May 16, 2021 | 03:39 PM
gonemad's Avatar
gonemad
Unless the M8 is different in a softail than a street glide the heel lever is just an add on
also deleted due to not knowing what the blazes I was talking about
Old May 16, 2021 | 04:15 PM
gonemad's Avatar
gonemad
Originally Posted by gonemad
It’s the same lever as the toe lever, just reversed. Piece of cake to install. Just need 3/16 allen wrench.
If you order the HD heel shift lever it will come with the correct black rubber/polymer shaft spacer.
I think I offered advice in error. My apology. The lever might be the same as a Street Glide that I referenced, but it appears that the shaft might in fact need to be changed judging from the P&A catalog for a 2018 softail heel shift lever. My apologies.
Old May 16, 2021 | 04:56 PM
Tampa Fatboy
I'd check with HD and see if there's a kit available.
New softails designed for toe shift only.
