2018+ Softail Models Breakout
Easy Pull Clutch Levers
Old Sep 20, 2021 | 07:17 AM
702's Avatar
702
Default Easy Pull Clutch Levers
I don't have any experience with these products and I'd like to find something to make the clutch pull easier for my wife on her new 21 Heritage.
Do these things perform in real life as the marketing claims they do?
Here's an example - http://www.elitemototech.com/product...bkcl-combo.htm
Is there a better alternative?
Old Sep 20, 2021 | 08:00 AM
FXLRyan's Avatar
FXLRyan
Not sure about those , I use 1FNGR levers and the clutch feels way better than the standard one. The brake feels better too since it is shortened compared to stock length
Old Sep 20, 2021 | 08:09 AM
702's Avatar
702
Can you help me understand what you mean by "feels better"? Is the clutch easier to pull? Did it move the friction zone?
Old Sep 20, 2021 | 08:24 AM
Hulkss's Avatar
Hulkss
You can buy a set of clutch plates from Rekluse that has more plates with lighter springs for the same torque capacity. Clutch pull is 30% less effort. I have it in my bike.
Call them about the lighter springs.
A new lever does basically nothing. A good adjustable lever may help by reducing the reach a bit.
Old Sep 20, 2021 | 08:39 AM
702's Avatar
702
Interesting, thank you. Is this what you have? https://www.fuelmotousa.com/i-238989...later-cvo.html
Old Sep 20, 2021 | 08:48 AM
NODYNA's Avatar
NODYNA
Levers with different configurations can help for some hands in placing the lever closer to the grip or allowing more finger contact. The lever by itself can not reduce effort it can only provide a different grip profile that allows more efficient use of the hand. The results are totally dependent on the users hand shape, strength and size.
As an example my wife benefits from a Soft on Brake lever. She is 5'2" with normal size hands for her size. The Soft Brake lever is angled to bring it closer to the grip so she can get more fingers contact with the lever. She now grips the lever further back on her finger not pulling the lever with just her finger tips.
Old Sep 20, 2021 | 10:51 AM
FXLRyan's Avatar
FXLRyan
clutch is definitely easier to pull. The way the 1FNGR clutch works you get rid of one of the little plastic pieces and the end of the clutch cable sits directly in the new clutch perch that comes with the lever. The friction zone did not move for me
Old Sep 20, 2021 | 11:06 AM
702's Avatar
702
If the angle is changed, does it reduce the throw of the lever?
Old Sep 20, 2021 | 11:07 AM
702's Avatar
702
OK, I understand - thanks.
Old Sep 20, 2021 | 11:20 AM
tunaman's Avatar
tunaman
Am I correct to presume it is a hydraulic clutch? If so, check out the Aim LFv3 (Light Force). It is a replacement clutch cylinder slave which is easy to install and works great to both reduce the effort required to actuate the clutch, and moves the friction zone closer to the grip.
I installed one on my ‘19 CVO Limited and it worked perfectly as advertised. I didn’t have any problems with the pressure, but wanted to move the friction zone.
