2018+ Softail Models Breakout
Screaming Eagle plug wires question
Old Dec 31, 2021 | 11:54 AM
squirrelsnest's Avatar
squirrelsnest
Welcome to the forums from Virginia............
Old Dec 31, 2021 | 04:16 PM
470004's Avatar
470004
Welcome from New York.
Old Jan 1, 2022 | 12:53 AM
Breakout2018's Avatar
Breakout2018
Stage III
Thank You. I have not check the plugs, they only have 4k miles on them. Thank you for the advise!
Old Jan 1, 2022 | 01:00 AM
Breakout2018
Stage III
They are seated and not crisscrossed. I thought at first they may not have been seated,but they were.
Old Jan 2, 2022 | 10:23 AM
sevebou63's Avatar
sevebou63
I've found the plugs on 2 of the last 3 bikes I've owned have been very loose from the factory. Almost hand tightened. Surprised the heck out of me. Not sure if you have checked that yet.
Old Jan 2, 2022 | 10:39 AM
FLSTC-Dave's Avatar
FLSTC-Dave
No problems on a "20 Softail Standard 107 install. Had to really work on one to click in. Pretty deep wells. I would work on them some more and make sure they're fully seated. You'll get em
Old Jan 3, 2022 | 11:47 AM
Calif Fat Bob's Avatar
Calif Fat Bob
Maybe just one of the new wires is bad. Try swapping back the original wires one at a time to see if you find a bad wire?
Just a thought.
Good luck! (watching this thread as I was going to swap my stock ones for SE)
Old Jan 3, 2022 | 12:15 PM
Keggr's Avatar
Keggr
No issues - put them on mine when the originals started to crack....
Old Jan 3, 2022 | 12:26 PM
strych9's Avatar
strych9
The OEM wires are difficult to remove on the plug end. What tools did you use to get them off? Is it possible that a plug was inadvertently cracked in the process? Go in reverse of install and recheck everything. Pull the plugs and make sure the ceramic isn't cracked. Test the wires, then reassemble with dielectric.
Double check that you didn't connect them incorrectly. A prominent member on this forum who is technically capable made that mistake. It can happen. Assume nothing.
bikridr69
Milwaukee Eight (M8)
Nov 8, 2021 01:06 AM
black05sunshine
Aug 25, 2019 07:36 AM
Geoff
Jun 30, 2018 11:40 PM
Riot Earp
Dec 13, 2013 07:58 AM
PWFD
Jun 22, 2011 12:48 AM
