Screaming eagle plug wires
Old Nov 6, 2021 | 02:36 PM
bikridr69's Avatar
bikridr69
Default Screaming eagle plug wires
I switched the plug wires to the screaming eagle 10 mm wires and now I have a kinda knock/tap/clicking noise at idle. I made sure all the plugs wire caps were seated. Not sure if it’s normal with the bigger wires or if I have a bad wire. Before I tear it back down does anyone have any knowledge of this.
Old Nov 6, 2021 | 06:07 PM
bikridr69's Avatar
bikridr69
Never mind. I found a plug cap not seated (even though I pushed them all down). The right front wire was not clicked. So I’ll take the mulligan on this one.
Old Nov 6, 2021 | 06:20 PM
Clayton24's Avatar
Clayton24
Cool u got it fixed is the main thing !
Old Nov 6, 2021 | 06:28 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Thanks for sharing.
Old Nov 8, 2021 | 01:06 AM
RocketyMan's Avatar
RocketyMan
Just as an FYI, the screamin eagle 10mm plug wires I believe are a carbon core type spark plug wire. You can measure the resistance at the terminals and help determine if the wires have good, realistic continuity. I'm on a softail--so my plug wires are a little different lengths. At any rate, I think I remember measuring my longest spark plug wire being around 5k ohms while the shorter one was obviously less. The plugs should also be a resistor type too and in the range of 5k ohms when measuring the center electrode. It seems the clicking noise you might have been experiencing was arcing. You must have good ears...and/or quiet pipes.
Pappy1
May 6, 2014 09:54 PM
2011 fatee
Mar 3, 2013 06:52 AM
Fred P
Jun 21, 2012 06:39 PM
RICHIEMACK
Feb 11, 2012 08:17 AM
VENNUM
Oct 19, 2011 10:59 PM
