2018+ Softail Models Breakout
Checking for intake leak.
Old Jan 28, 2022 | 09:32 AM
martin10's Avatar
martin10
Default Checking for intake leak.
I have a reason to thing I might have a slight intake leak. It's really hard to spray anything around the intake on these M8's because there is so much stuff in the way. I have read a tip for checking for a leak but have read two different versions. Pull in the clutch and close the throttle. One source said the revs should drop to zero if there is NO leak. That makes sense to me. The other version said if the revs drop to zero there is a leak. So which is it. Appreciate any input on this or any other tips
Old Jan 28, 2022 | 10:47 AM
702's Avatar
702
Do you have a high idle?
Old Jan 28, 2022 | 09:43 PM
Agoober's Avatar
Agoober
Like 702 aksed(lol) , a high idle could mean an air leak in the intake.
Spraying WD around a bike to find an air leak is a good thing , it always makes bike bits look shiny new.
An air leak will pop or explode under acceleration and possibly pop and fart on decel depending on where the leak is.
An erratic idle could be an intermittent air leak or electrical fault.
Old Jan 29, 2022 | 06:11 AM
martin10's Avatar
martin10
Bike idle is stable. Isn't high. It sounds like it is running slightly rough at idle. Fuel Moto suggested I check for an intake leak. There is so much stuff in the way I can't even see a lot of the intake. Much less spray anything around the seals.
Old Jan 29, 2022 | 09:50 AM
chopper_man's Avatar
chopper_man
Use an un-lit propane torch to get in around the intake.
Old Jan 29, 2022 | 01:58 PM
Johnchev89's Avatar
Johnchev89
Maybe there is nothing wrong, that 22x cam will have alot more idle lope than a stock M8.
Old Jan 29, 2022 | 03:12 PM
sandrooney's Avatar
sandrooney
I put a hose on the spout of a propane torch to make it longer and more flexible to get in and around the intake.
Old Jan 29, 2022 | 05:12 PM
martin10's Avatar
martin10
That's true. And likely the case.
Old Jan 30, 2022 | 11:23 AM
Burbur2's Avatar
Burbur2
I got same cam installed by FM idle is set at 950rpm just so you know. I also used torch to check for leaks on my previous bikes it is not messy.
Old Jan 30, 2022 | 05:59 PM
natural gasser's Avatar
natural gasser
I do what sandrooney said. works like a charm.
And DON'T light the torch LOL.
e_minor_pentatonic
Aug 24, 2020 03:51 PM
94 lr
Jul 13, 2013 11:17 AM
Edster 69
EVO
18
Jun 9, 2012 06:27 PM
hboat
Exhaust System Topics
Mar 5, 2012 03:11 PM
HDF Tech
Engine Mechanical Topics
Jun 24, 2005 06:33 PM
