2018+ Softail Models Breakout
seat screw base when switching two up to single
Old Apr 27, 2022 | 06:04 PM
52AllisCA's Avatar
52AllisCA
Default seat screw base when switching two up to single
Probably a Noob question, but when switching from a two up to single seat, what do you do with the screw base where the two up normally is? do they make some kind of retainer to make sure it does not fall out?
Old Apr 27, 2022 | 06:15 PM
aviscomi's Avatar
aviscomi
Use the screw you had taken out
Old Apr 27, 2022 | 06:37 PM
07UltraGuy's Avatar
07UltraGuy
I put a rubber O-ring on the threads, and when it isn't holding the 2-up seat, it goes back into the nut on the rear fender.
The O-ring makes it not vibrate loose.
That, or I put it in the windshield bag so I can search for it for an hour the next time I swap seats.
Old Apr 27, 2022 | 06:51 PM
Iceman24's Avatar
Iceman24
I added fender bib & used black screw to secure...there are a multitude of options - just use your imagination.
Old Apr 27, 2022 | 07:26 PM
Kenelz's Avatar
Kenelz
I just put the screw back in so I don't lose it.
Old Apr 28, 2022 | 08:54 AM
snake_eyes's Avatar
snake_eyes
Are you talking about the metal, threaded, female side? It's attached to the fender by a plastic E-clip and won't fall off.
Old Apr 28, 2022 | 08:59 AM
52AllisCA's Avatar
52AllisCA
Yes the female side going through fender. Am worried about accidently putting pressure on it and falling out. Figured there has to be some kind of protective cover.
Old Apr 28, 2022 | 10:18 AM
motorend's Avatar
motorend
There is, its the screw. Or you can remove the whole thing and get the Harley plastic insert. But if your going back and forth I would use the thumb screw.
Old Apr 28, 2022 | 04:57 PM
martin10's Avatar
martin10
Harley makes a flat plastic emblem you can push into the female part. Only costs a couple of bucks. Most dealerships stock them
TwoBlue02
29
Dec 29, 2021 08:20 PM
dproto09
Apr 30, 2013 04:34 PM
m1crazy
Jul 13, 2011 08:12 PM
bucker18
EVO
Sep 1, 2010 07:04 PM
LuvtheMud
Sep 16, 2007 02:52 PM
