2018+ Softail Models Breakout
HELP! No Throttle/Check Engine
Old Jun 19, 2022 | 12:49 PM
Drewmarkers's Avatar
Drewmarkers
Stage IV
Default HELP! No Throttle/Check Engine
Hey folks!
Installed full V&H short shots recently and not sure if this is the culprit, but I noticed when I tried to fire her up that I had check engine and no throttle response whatsoever.
I even got the V&H FP3 and ecu mapped it and no codes popped up. Yet on the bike still have check engine. (Diagnosed and had a code for rear brake voltage but cleared it after looking at rear brake plug and noticed it was fine along with the cable wiring fine). So now I’m out of options…
Please help! !
I have a 2018 (throttle by wire) FXBB. Just got her too.
I know I can’t bring in to stealership because pipes would void my warranty.
Thanks
Old Jun 19, 2022 | 12:56 PM
OldMike's Avatar
OldMike
Originally Posted by Drewmarkers
Hey folks!
Please help! !
Thanks
FP3 and age of bike kills warranty so what's the diff.
Old Jun 19, 2022 | 03:19 PM
Drewmarkers
Stage IV
I just got the warranty with my purchase a month ago.
Although I did not know they could tell an fp3 was used in the ecm and it’d void it as well. That sucks.
But you have any help for my bike ?
Old Jun 19, 2022 | 03:47 PM
Durham man's Avatar
Durham man
Check 02 connections maybe.
Old Jun 19, 2022 | 04:28 PM
OldMike's Avatar
OldMike
This and maybe put the stock tune back in.
Old Jun 19, 2022 | 06:05 PM
Screamin beagle's Avatar
Screamin beagle
I'm with Durhaman...recheck the o2 connections. Make sure they're not crossed up. Unplug, clean and put dielectric grease in the plug for the throttle body and make sure it's plugged in correctly. You should put the stock tune back in first and see if that clears the issue. You're worried about loosing the warranty if you bring it to the dealer...so what's the sense of having the warranty if you can't use it anymore? It's gotta be something simple that's wrong, it's just going to take a little diagnosis to figure it out...you'll get there.
Old Jun 19, 2022 | 06:08 PM
OldMike's Avatar
OldMike
Indeed, he might have bumped that installing the exhaust.
Travelnsoldier
Twin Cam Motors
17
May 28, 2021 10:24 PM
Thumperbutt
May 24, 2021 12:39 PM
galxl68
May 2, 2019 10:44 PM
09rkpolice
Feb 9, 2013 08:03 PM
ScreaminEagle2007
Mar 15, 2012 08:35 PM
