2018+ Softail Models Breakout
Hard Start
Old Sep 20, 2023 | 08:07 PM
abolton89's Avatar
abolton89
I dealt with that on my 18 heritage 107. I felt it was vapor lock related
when I got my tune from Fuelmoto on my PV4 it went away completely. never had it happen since.
Old Sep 20, 2023 | 08:10 PM
whylee's Avatar
whylee
I dont think the clock would clear itself if the compression release was bad, still sounds like battery or a bad connection somewhere.
Old Sep 20, 2023 | 08:52 PM
GalvTexGuy's Avatar
GalvTexGuy
Originally Posted by Monteman1971
Ok, google search, the lurch seems to be normal.
The automatic compression release (ACR) seems to correspond with my problem. I'm looking into that further.
I'll let you know how I make out. Unless there are other things to check out.
Thanks again,
Steve
Yeah, but what I was getting at is starting in gear, especially if the bike is lurching, puts more stress on the battery. That’s why I asked for battery make and CCA.
Old Sep 21, 2023 | 07:09 AM
Monteman1971's Avatar
Monteman1971
Agree, but possibly because attempting to start the bike is taking an excessive amount of power, the surge interrupts the clock?
Old Sep 21, 2023 | 07:11 AM
Monteman1971
I'll need to pull the battery in any case but I got it at Harley and asked for the correct battery so I would assume it's the correct one... but who knows. When I pull it, I'll let you know.
Old Sep 21, 2023 | 07:14 AM
Monteman1971
Vapor lock is typically on a hot engine, this happens hot or cold and it's intermittent.
Thanks everyone for all the ideas... it's giving me places to look.
Steve
Old Sep 21, 2023 | 07:53 AM
abolton89's Avatar
abolton89
Steve
it happened hot or cold with me as well. Vapor lock was just an idea. But I really think it was factory tune related.
since the flash, I don’t even think about the hard starts anymore. I was actually shocked the flash had got rid of the issue.
Old Sep 21, 2023 | 09:13 AM
Tozco's Avatar
Tozco
Another part of the equation is the starter itself.
Old Sep 21, 2023 | 09:23 AM
Rounders's Avatar
Rounders
I always start the bike in neutral but I just tried it in gear and the bike did lurch forward just a bit. What does that mean? The bike has 17k on it and the clutch has never been adjusted so I would think if anything it's loose and not tight.
Your thoughts?
What I think is you need to maintain your bike
17k and you have not adjusted clutch???? Adjust clutch and try again. May or may not help. I start in neutral.
Also what brand battery?
Curious, if you put charger on high does it start better?
The automatic compression release is interesting, my first bike with them. If you give bike quick start and then try again any better? I've done this to decompress bikes when hot.
Old Sep 21, 2023 | 02:29 PM
Uncle G.'s Avatar
Uncle G.
Your thoughts?
It means your clutch is dragging a bit. That’s very common with Harley wet clutches, even when properly adjusted, especially when cold starting.
