2018+ Softail Models Breakout
Occasional startup issue after swapping spark plug wires
Old Oct 1, 2023 | 10:53 PM
gthmnyt2580's Avatar
gthmnyt2580
Default Occasional startup issue after swapping spark plug wires
Looking for advice. A couple of weeks ago, I swapped out the stock spark plug wires on my 2020 Softail Slim with the red HD "phat 10mm spark plug wires" and now I'm having the occasional startup issue where the bike is sometimes struggling to start up. I had the bike serviced for its 10k service back in March of this year which included replacing the spark plugs with NGK Iridium CR9EIX ones. I'm seeing a couple of youtube vids and a couple of articles saying that the wires and plugs should be replaced at the same time due to potential "cross contamination" between the new wires and the old plugs. Should I have replaced the spark plugs when I swapped out the wires anyway? Thanks in advance!
Old Oct 1, 2023 | 11:09 PM
WONKEY's Avatar
WONKEY
I wonder if the new plug wires have too much resistance for the bike or plugs.
Old Oct 2, 2023 | 03:27 PM
TomHFXSTCI's Avatar
TomHFXSTCI
Stage I
Default RES 10MM Spark Plug Wire Swap
I am having the same issue with my 2010 FXSTCI since swapping out the spark plug wires with the RED 10MM Harley ones. I put the old plug wires back on and get the same thing. When it turns over it sounds like the timing is off, woofs a little. Things I checked so far:
1. All fuses including fuel pump fuse were good.
2. When I turn the ignition on I hear the fuel pump kick in and there's bubbles in the fuel tank.
3. I thought I may have old fuel so I siphoned it out and relaced with 4 gal. fresh Unleaded Premium.
4. Charged the battery and had it tested. 12.6-7 Volts, 326 CCA (above specs - 310), Cleaned battery terminals and all contacts.
5. There is spark and fuel in both cylinders, checked plug gap.
6. Checked for diagnostic codes; none.
I don't know what to check next. All help is appreciated. I live in west central Wisconsin, it's 87 degrees out, and my bike won't start....
Sometimes when you do something ridiculous, you learn a lot in the process!
PLUG WIRES WERE REVERSED....
Old Oct 2, 2023 | 03:58 PM
gthmnyt2580
That might have been a possibility or I pinched one of the new cables during the install. I ended up picking up 4 new spark plugs anyway because it looks like only 2 of the 4 original spark plugs were replaced at my 10K service from some reason. I did some trial and error with the OLD and NEW cables and it turns out that the NEW cables were the issue. I just put the old stock ones back on. Unfortunately, since the spark plug cables are considered an "electrical item", it's not returnable. Plus I missed my 14 day return window, anyway. It's a shame because I like the extra red color pop from the wires. I'm just glad that the bike starts up fine again.
Sorry that you're having a similar problem, @TomHFXSTCI. Hopefully somebody can chime in on other possible solutions for you. Mine seemed to be a simple fix for my issue. Fingers crossed that was it though.
Old Oct 2, 2023 | 04:50 PM
Jackie Paper's Avatar
Jackie Paper
May be the plugs. Especially if you do mostly around town and then a hot long interstate run.
That type of plug is easy to cold foul on a Harley. Now they will go 100k in a Honda car.
The original conventional plugs are much better.
Now that's just my opinion of what I've experienced. They need high voltage spark and perfect fuel air ratio. That small tip if it gets a tad of carbon on it will glaze over with a hot run.
Then it's like it has a glass insulation over it.
Unless your Harley sits in the sun and such, the wires should last a long time. My 04 has the original on it. That silliness that they match the plugs. Tin men spin that BS.
Old Oct 2, 2023 | 05:58 PM
cobra23's Avatar
cobra23
When I put the 10mm wires on my Fatboy, I got a check engine light that was constant. I took the bike to the dealer and they told me the light was on because "I tried to start the bike without any spark plug wires." And they called themselves mechanics.
Months later, I was talking to a dyno guy and happened to mention the check engine light. He said that it was because of the 10mm spark plug wires. So I put the stock ones back on and no more check engine light.
I would put your stock wires back on and go from there
Old Oct 2, 2023 | 05:59 PM
702's Avatar
702
If an HD conventional plug ohms out at 6.0xxK ohms resistance, and an NGK iridium ohms out at 6.0xxK ohms resistance, why is it that the iridium needs high voltage?
Old Oct 2, 2023 | 07:39 PM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
"NGK Iridium CR9EIX ones"
I would highly recommend NOT buying these unless you can verify where they came from and the shop knows they're legit ones they're selling.
These plugs got targeted by counterfeiters and the market was flooded with fake ones.
This is why I decided to get the SE Sparkplugs instead. They arent targets for counterfeiters.
Plus it doesnt seem that these Iridium/performance spark plugs are of much advantage in an M8 either.
The stock ones are pretty good.
Old Oct 2, 2023 | 07:57 PM
702's Avatar
702
The ones I just installed in my Street Glide are legit. It's easy to tell, and they should be ohm checked too.
Old Oct 2, 2023 | 11:00 PM
Rounders's Avatar
Rounders
Go back to stock, and see if it still does it?????
Ndoggct
Sep 21, 2016 07:02 PM
oldairboater
Jun 24, 2011 09:43 PM
scorchedearthpolicy
Jul 6, 2010 08:34 PM
zaxcar
EVO
Oct 18, 2009 03:44 PM
paintballoma
Jun 6, 2007 11:18 AM
