2018+ Softail Models Breakout
Transmission Fluid Add/Full Difference
Old May 6, 2024 | 05:35 PM
Number 6's Avatar
Number 6
Default Transmission Fluid Add/Full Difference
Does anyone know how much transmission fluid is between the ADD and FULLL marks?
2024 Heritage
Old May 6, 2024 | 06:39 PM
GalvTexGuy's Avatar
GalvTexGuy
The manual says the level should be between the add and full marks. You’re good, but if you insist on adding, a couple of ounces should be okay without overfilling.
Old May 7, 2024 | 01:24 PM
Number 6's Avatar
Number 6
Thanks TexGuy, I was at the ADD mark.
Old May 7, 2024 | 02:09 PM
Goose_NC's Avatar
Goose_NC
Originally Posted by Number 6
Does anyone know how much transmission fluid is between the ADD and FULL marks?
2024 Heritage
Judging by the Harley Owners manuals, not even Harley knows how much tranny fluid gets it to the full mark. Much less the amount to go from ADD to FULL. They say add 28 ounces, then fill to between the add/full mark.
I now just dump a quart into the tranny and run it. I check tranny and engine fluids frequently. Only check the primary if the tranny fluid is low. I have not had any transference issue between tranny and primary since adding the primary vent, and only running the quart of fluid.
Old May 10, 2024 | 09:16 AM
Uncle G.'s Avatar
Uncle G.
The book says 24 ounces. If checked on the side stand the way the book says, it will barely show on the stick. A full quart shows "full" on the stick, so now I just put in a quart and forget about it.
Old May 11, 2024 | 11:40 AM
barneyboy's Avatar
barneyboy
What book says 24 ounces?
Old May 11, 2024 | 12:31 PM
joenc's Avatar
joenc
my 2023 fatboy service manual says 24 oz for trans replacement/fill
Old May 11, 2024 | 12:58 PM
GalvTexGuy's Avatar
GalvTexGuy
I wonder what changed? My manual says 28.
Old May 11, 2024 | 12:59 PM
Number 6's Avatar
Number 6
My 2024 Heritage manual says 28oz for a full load.
Old May 11, 2024 | 02:38 PM
Rounders's Avatar
Rounders
I don't have a m8, but it is interesting how much fluid changes year to.
I have three tc all have different primary and tranny specs. Something to keep in mind in these threads
