Straight bar engine guard for my Heritage
- it tries to absorb all the force of impact with the groundat one POINT versus a wider contact area, so there will be a concentrated force on that one point, and the length of the bar gives that force leverage to BEND the bar, especially if the bike is moving at the time of the fall
- The point can also injure a rider in a fall, especially if the bike is in motion when it falls, by stabbing him
A full loop shaped engine guard:
- distributes the impact force over a MUCH broader area
- Is more resistant to being bent
- is more resistant to shearing its mount bolts because there are MORE mounting bolts (top AND bottom), and the bottom bolts are subjected to a compression force versus a shear force, and so are far less likely to be broken by the impact
- Provides a choice of many places to mount highway pegs if you want highway pegs
- Is really not highly visible if you choose "black" versus chrome. If you wANT the higher visibility, then choose chrome.
Jim G
Jim G
One advantage of the bar type that she uses is the end tips are replaceable. Scars on the hoop types stay there, though its down low and effectively invisible.
- Sand it smooth and repaint
- Sand it smooth and powder coat
- Cover the scrape with black heat shrink black tubing or slit tubing
- Cover the scrape with highway pegs
Jim G
https://www.bungking.com/2018-2023-softail/
hth,
T.
One advantage of the bar type that she uses is the end tips are replaceable. Scars on the hoop types stay there, though it’s down low and effectively invisible.
I've used these guard protectors from E-Glide Goodies on several bikes including my Heritage. They are not expensive and have saved my guards when I'm practicing slow speed cone maneuvers in parking lots
https://eglidegoodies.net/store/Moto...ors-p485456539
Jim G
"Resistant to being bent" up to a point. When I was hit by a fellow motorcyclist a few weeks ago, my engine guard bent forward like it was made of butter.
Think in terms of the crash absorption structures used on modern cars to protect the occupants and keep the damage as much as posible restricted to EXTERNAL sheet metal versus much costlier items like engines, transmission, and rear axles. You want 3D shapes that will deform (bend) to absorb impact and energy, but will not "break" and will NOT bend enough to expose more costly parts, or YOU, to damage.
Jim G
