2018+ Softail Models Breakout
Fatboy Shifting Problems
Old Jun 30, 2024 | 06:19 PM
Uncle G.'s Avatar
Uncle G.
Originally Posted by Tozco
Cold engine first gear clunk can be completely avoided by pulling the clutch lever and holding it at the grip for 5 seconds before putting it in 1st. It should go in silently.
Don't do this on a warmed up engine, it can cause a clunk when everything is warmed up. For a quiet easy shift into first from neutral , the whole idea is to have the transmission input shaft not spinning at idle speed speed while the output shaft is stationary when you are stopped.
I find it takes more than 5 seconds when the engine is cold-more like 10-15 seconds minimum.
NSM TINY
Apr 2, 2024 04:47 PM
huey_da_jugg666
Oct 24, 2022 04:28 PM
Joel282
Feb 18, 2018 05:42 PM
Joel282
Oct 24, 2017 10:13 AM
zoomie67
Apr 17, 2007 01:20 PM
