2018+ Softail Models Breakout
Help!
Old Sep 4, 2024 | 01:16 PM
Pointyhairboss's Avatar
Pointyhairboss
6th Gear
Angry Help!
Hi folks, I think I might have probably done something stupid.
i have just fitted some Oberon adjustable levers and now it won’t start.
The headlight comes on when the main switch is on and the
fuel pump works but there are no lights on the dash and no
starter motor.
Is it possible that a wiring problem on the handlebar switches could
cause this? I can’t see anything else out of place.
Thanks in advance.
2021 Sport Glide
Old Sep 4, 2024 | 01:24 PM
Powermankw's Avatar
Powermankw
Neutral safety switch. Are you starting in neutral? I got used to not because you don't have to... But then it went out and it was a minor panic when I thought I was stranded...
Old Sep 4, 2024 | 02:04 PM
MrLongbeard's Avatar
MrLongbeard
What he said, knock it out of gear and it'll fire right up
Old Sep 4, 2024 | 10:58 PM
WS6_Keith's Avatar
WS6_Keith
Clutch switch? Since that's where you just made modifications....
Old Sep 5, 2024 | 04:41 AM
havinabubble's Avatar
havinabubble
turn it up to 4
4 and higher and it'll start in gear... as mentioned its to do with the neutral safety that the Oberons dont engage correctly from 1-3
...just knock it out of gear and it'll fire up from 1-3
Have them on my FLHXS, wifey has them on her FXBB, both luv 'um
starter motor.
Thanks in advance.
2021 Sport Glide
Old Sep 5, 2024 | 01:31 PM
Pointyhairboss
6th Gear
Hi, I have checked and it is in neutral.
The headlight comes on but there are no lights on the Speedo.
The fuel pump powers when the ignition is switched on but none of the
other handlebar switches work.
Also the odd thing is if the bike is leant on the side stand, switching the
ignition switch on does nothing, not even the headlight works.
Old Sep 5, 2024 | 01:35 PM
Pointyhairboss
6th Gear
When changing the clutch lever, In order to get access to the circlip I rotated the switch cluster about 45 degrees.
Is it possible this could have caused damage to the wiring?
Old Sep 5, 2024 | 02:12 PM
Uncle G.'s Avatar
Uncle G.
Yes.
Old Sep 5, 2024 | 08:15 PM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
I have oberon Adjustables. They are fantastic levers but the surface that pushes the switch is too shallow.
You can get a small square of 3M tape and stick it onto the contact surface, but leave the red side peel tape on.
That'll fix the switch issue.
Old Sep 16, 2024 | 09:09 AM
Pointyhairboss
6th Gear
Ok so yesterday I had a look and found a blown fuse (5A). Replacing this made the dash lights work and it will now start.
The reason for the blown fuse, apart from me being a plonker, was that I managed to break 3 wires in the clutch lever switch cluster.
So out with the soldering iron and heat shrink and now everything is working 😀
You live and learn. Be more careful next time lol
Thank you all for your help 👍
CMF
Mar 15, 2024 02:26 AM
bdibs
Jun 6, 2022 05:36 PM
Softail332
Electrical/Lighting/Alarm
Nov 13, 2017 05:29 AM
Houston_t
Dec 11, 2012 03:45 PM
3trdmarine
Jul 15, 2010 09:55 PM
