2018+ Softail Models Breakout
25 FXLRS battery
Old Nov 22, 2025 | 08:23 AM
MesquiteFLD's Avatar
MesquiteFLD
Default 25 FXLRS battery
How the heck do you access the battery to install a battery tender cable?
Old Nov 22, 2025 | 08:49 AM
CoolBreeze3646's Avatar
CoolBreeze3646
On a 2025, it should already have a battery tender cable installed. Check your owner's manual, should be under the side cover where the fuses are.
Old Nov 22, 2025 | 09:09 AM
MesquiteFLD
I looked, did not see a cable.
Old Nov 22, 2025 | 09:37 AM
$tonecold's Avatar
$tonecold
Look again, it’s there. It will be under the right side cover. It’s referenced on pg 159 of your owner’s manual.
Old Nov 22, 2025 | 09:43 AM
MesquiteFLD
Thanks
I was looking for an actual tender cable hanging somewhere.
As soon as it warms up a bit I'll charge it and myself with a ride.
Old Nov 22, 2025 | 10:10 AM
$tonecold's Avatar
$tonecold
I think the dealerships used to pull them out when they did the initial setup. Obviously they don’t do that anymore. I just left mine out from under the side cover after I pulled it out. I can’t remember if I had to secure it with a zip tie or not.
Old Nov 22, 2025 | 11:01 AM
MesquiteFLD
I was covered with black tape,made it hard to find. Nice they put it on at the factory.
FenderGuy53
Jan 17, 2025 01:12 PM
BSilver
General Topics/Tech Tips
Jul 14, 2017 07:27 AM
HOG WRANGLER
May 8, 2010 03:17 PM
Hidalgo
Jan 6, 2008 12:25 AM
