2024+ Center-Cooled Touring Models 2023.5+ CVO and 2024+ Road Glide/Street Glide/Street Glide Ultra Center-Cooled Gen 2 M8 Touring models
Preloading only the right side shock?
Old Apr 8, 2025 | 09:20 AM
bill from tn's Avatar
bill from tn
Originally Posted by Jackie Paper
Swing arm is one piece. They work together. Shocks work together as a unit. No different then the front sliders working together as a unit.
The carring capacity and damping is based on total of two.
This is the answer. The swing arm is pretty beefy. I suspect the weak link is the bushings that the swing arm pivot on but as long as clearance is in spec it can’t rock too much.
I believe one shock is compression and one rebound, but not sure about that.
Old Apr 8, 2025 | 03:16 PM
RK4meStA's Avatar
RK4meStA
I guess it just seems to me that all the weight is on the preloaded shock/spring as the unpreloaded one is really just stretched to the same length as the preloaded shock but not supported by the preload adjustment. Maybe that’s not how it works at all and I’m thinking it works differently than it actually does?
Old Apr 8, 2025 | 03:28 PM
mjwebb's Avatar
mjwebb
I think what some folks are forgetting is the hydraulic left side preload adjustment was the only preload adjustment offered on the previous gen models..so it alone was designed to to support both shocks
Old Apr 9, 2025 | 05:25 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Originally Posted by RK4meStA
Can someone explain how preloading the right side shock and not the left side doesn’t cause some type of imbalance?
It does cause a force imbalance, but the swing arm is designed to handle the load, so no problem.
Not really any different than the single leg swing arm BMW likes on their bikes. If that swing arm was weak, that wheel would be flexing on the axle. But the whole thing is strong, so it doesn't.
Similar the uneven set of springs on your bike. The swing arm is strong enough to not flex appreciably under the load.
Harley went even further with the shocks themselves. One resists compression, the other resists expansion. But again, the swing arm is strong enough to handle it.
Old Apr 10, 2025 | 08:47 PM
streeter's Avatar
streeter
The left side has a stiffer spring and different base internal dampening. The concept is used in many front fork assemblies where one is for compression and the other for rebound. While this isn't quite the same, its all in the spring rates, and internal dampening to achieve the intended result.
DayDrivingDan
May 31, 2017 07:35 AM
Bubba Zanetti
Sep 11, 2015 02:58 PM
Iron lHorse
May 10, 2014 07:43 AM
djwhaley
Nov 9, 2013 10:33 AM
robbieaz62
Apr 5, 2011 06:16 PM
