2024+ Center-Cooled Touring Models 2023.5+ CVO and 2024+ Road Glide/Street Glide/Street Glide Ultra Center-Cooled Gen 2 M8 Touring models
Preloading only the right side shock?
Old Apr 7, 2025 | 02:29 PM
RK4meStA's Avatar
RK4meStA
Default Preloading only the right side shock?
Can someone explain how preloading the right side shock and not the left side doesn’t cause some type of imbalance? My last bike (2014 road king ) had air shocks so it wasn’t an issue. My previous Dyna had progressive shocks and you had to adjust preload equally on both sides. I understand the procedure for my 2024 street glide and I’m not questioning that it’s correct I’m just wondering why it doesn’t cause an imbalance.
Old Apr 7, 2025 | 02:33 PM
smitty901's Avatar
smitty901
Have had 5 bikes with the current style HD shocks. How and why they work I do not know. What I do know i they work and I have had no reason to change them.
Old Apr 7, 2025 | 02:41 PM
RK4meStA's Avatar
RK4meStA
I’m sure it does work. I just like to know how things work. I’m sure there is a simple explanation but it seems that all the weight would be on the right side spring 🤷🏻‍♂️
Old Apr 7, 2025 | 03:17 PM
Check6's Avatar
Check6
It works, but barely. As an engineer it makes no sense. And yes, it does put more strain on the right side shock, but I've never felt like it was imbalanced. On a Standard Electra Glide in just plain sucked. It's just a way to save money.
I've had the air ride suspensions on past E-Glides and a Road King. Preferred them much over the latest E-Glide standard I just got rid of due to the suspension. I wasn't willing to put $3K into it for a Legends system.
I traded straight up for a Sport Glide that has a soft tail single shock system on it. Much better, and much easier on my beat up knees with the weight reduction.
Pappy35's Avatar
Pappy35
I've been riding since 1982, but my first-ever HD was a new '22 Road King. Now I'm on a new '24 Street Glide so evidently I like these things. Lol
I still question why only one side is for preload. I'm an engineer and agree that it seems like it would introduce a lateral bending moment (frame twist), but I've never noticed any issues so I just keep riding. Like you, I'd be very interested in a detailed response from someone who understands suspension dynamics <cough...Kevin Cameron...cough...cough>
Old Apr 7, 2025 | 04:54 PM
mjwebb's Avatar
mjwebb
start by reading your OM description and explanation of their intended purposes..if you need more than that to satisfy your curiosity maybe call an aftermarket suspension tech support person, like Progressive, etc. Companies like that that only do suspension and have for decades are subject matter experts.
Old Apr 7, 2025 | 05:23 PM
RK4meStA's Avatar
RK4meStA
The OM doesn’t answer my question. I think it’s perfectly acceptable to ask a question like this in this forum. In fact I think the purpose of this forum is to bring owners of twin cooled motorcycles together to share experiences educate each other and help one another out. If no one has an answer that’s fine but it doesn’t hurt to ask because Ive found a wealth of knowledge is possessed by members of this forum. And the best part is if someone doesn’t know and doesn’t want to answer they can just scroll on by….
Old Apr 7, 2025 | 05:46 PM
mjwebb's Avatar
mjwebb
ease up cowboy, you make it sound like I admonished you here for asking your question..which I didn't, rather gave you an excellent suggestion on where to find the answer you are looking for....trying to help you like this forum is for..you're welcome
Old Apr 7, 2025 | 05:55 PM
Southernspeed's Avatar
Southernspeed
They must have really beefed up the swing arms. I've ridden several customer bikes (Pans, Shovels, Evos) that had a blown shock on one side and it created horrible flex and handling.
Some bikes now have the front suspension set up with comp damping on one side and rebound on the other. This also struck me as odd but it works🤷‍♂️
Old Apr 7, 2025 | 05:56 PM
Jackie Paper's Avatar
Jackie Paper
Swing arm is one piece. They work together. Shocks work together as a unit. No different then the front sliders working together as a unit.
The carring capacity and damping is based on total of two.
