Power Vision Released
@Taxgod4u Can't you use your PV-2B with a different cable and a firmware update??
I'd call DynoJet..
I was messing around, updating both my PV2B tuners (don't ask, long story), anyways, I did a firmware update on one of them, and then it wouldn't connect to my bikes??????
I realized that I used the new '21+ Firmware update and '21+ tune database. I don't have a '21+ Harley, so I updated it again but this time with the newest version of the J1850/canbus firmware & database. Then my tuner worked with my older bikes again.
So apparently you can switch any PV full service tuner back & forth between a J1850/CanBus tuner and '21+ tuner, then you just need the appropriate cables use it on the appropriate ECM...
I believe the actual tuners are the same, there are just three different cables (J1850, CanBus, & '21+) and 2 different firmware updates (J1850 with CanBus firmware and '21+ firmware).....
I'd call DynoJet..
However, I don't think there will be any combination of cables and FW/Tune Database for PV2* that will ever work with the newer Harley ECM ('23+, whatever it's called). This will be PV3 and PV4 only AFAIK.
Maybe that would apply to the 2023.5 and later.
I could easily be wrong.
