Air Suspensions All you Air Ride Suspension Owners can discuss your Rides here
Shotgun install help
Old Mar 5, 2011 | 02:25 PM
KeeBee's Avatar
KeeBee
Default Shotgun install help
Having a rough time getting the shoulder bolt in on the right side due to this tube and bolt in the way. Can I remove them? Not sure what they are and could not find it in the service manual on what they are for. Looks like if I take the hose out something is going to leak.
Attached Thumbnails Shotgun install help-dsc01333.jpg   Shotgun install help-dsc01334.jpg
Old Mar 5, 2011 | 02:32 PM
KeeBee's Avatar
KeeBee
ugh looks like that is the oil drain line. It is smashed right up against it can't get the bolt in. argh
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
That is the oil drain hose. Do not disconnect. I'm looking at an01 softail right now and there is plenty of room it must be different on the '11
Drew
Old Mar 5, 2011 | 02:55 PM
KeeBee's Avatar
KeeBee
I am an idiot lol. I let it down to get the compressor in I just had to jack it back up. Problem I am running into now is the shoulder bolts do not fit easily into the Shotgun shocks. Slides in and out of the stock shock fine but the not the new shock system. Making it near impossible to thread into the swing arm.
Old Mar 5, 2011 | 03:39 PM
story808's Avatar
story808
Adjusting the height of the rear tire will help you get away from the oil drian line.
Old Mar 5, 2011 | 05:27 PM
bluedemon06's Avatar
bluedemon06
Make sure to put anti sieze on the shoulder bolts might help them slide in beter to
Old Mar 5, 2011 | 08:05 PM
Blk and Chrome's Avatar
Blk and Chrome
mine is an 08 and they went in with no issue, jack the tire up and or down till you find the right spot to install. the bolt won't go in the shock? either? make sure there are no burrs on the bolt
Old Mar 5, 2011 | 09:59 PM
Robcat's Avatar
Robcat
+1 on the never seize. The shoulder bolts were really snug for me as well. Just keep adjusting the jack under your rear tire and find the right spot. They will definitely go in there.
Old Mar 5, 2011 | 10:40 PM
J.D.1's Avatar
J.D.1
Former Sponsor
The stock shoulder bolt is used on the rear eyelet of the shotgunshock and it is a precise fit inorder to insure solid suspension and no slop. Some bolts may be tight and can be made to fit by rotating bolt in bushing. The bushing has a teflon liner and conforms to the size of bolt as the purpose of the teflon is to wear on the shouder of the bolt and aid in lubrication.
Old Mar 6, 2011 | 09:30 AM
Gary Deuce's Avatar
Gary Deuce
It was very snug for me too. I had my friend help hold the shock up and give the bolt a little push with a screwdriver while I turned it. I spent a while trying to do it myself, but with my friend and the screwdriver it basically went right in.
