Stereo Upgrade?
Old Nov 15, 2014 | 05:46 AM
UltraNutZ's Avatar
UltraNutZ
Originally Posted by Last302
I did not take the time to scroll back to see who posted it(lazy) but one of you wrote that be sure to have 4v RCA outputs when referring to the aftermarket h/u. I obviously know what the RCA jacks are but what does the 4v (just assuming voltage) do for the system, how would I know if my h/u was 4v, and if it was something else, what issue if any would arise? I'm trying to educate myself much more now that I have recently done a system on my RG and am seeing little issues I'm not sure are normal or if I'm willing to live with. Thx as always!!
Probably me. You won't have issues either way just that a 4v output vs a 2v output is just that, a higher output voltage. This means your amp input will have a higher v input therefore gains can be adjusted down a little more because of the cleaner/higher volt inputs.
What head unit do you have?
Old Nov 15, 2014 | 06:42 AM
Gannicus's Avatar
Gannicus
Care to elaborate on the little issues you are seeing? One thing I see in your signature that always sticks out in my mind is you have the Hertz speakers paired with the JL 400/4 amp. Not a match made in heaven unless you have that amp bridged. Those hertz speakers require much more power than 75 watts to drive em.
langwilliams
Audio Systems
11
Jun 20, 2018 06:08 AM
rocmytims
Audio Systems
Mar 23, 2018 09:56 AM
b_townchops
Audio Systems
Mar 19, 2014 07:14 PM
Kingfever
Audio Systems
27
Dec 24, 2013 03:44 PM
Biggzed
Sep 23, 2011 12:13 AM
