take a 2 pieces of flat aluminum bar as long as the width of the amp
drill 2 mounting holes in each piece
use clip nuts(speed nuts) and screws
mount amp above radio brackets with aluminum mounts under radio bracket
this sandwiches the radio bracket between the amp and the aluminum
The end result is a gap between Aftermarket HU and amp and a secure mount for the amp.
