Anyone have any troubles with blown BT 7.1 speakers in the front fairing? I have the 4180 amp and usually set the volume at 5 or 6 bars on the HK radio. Everything was okay until about 2 hours into a drive down to the Smokey mountain's.
I have the BT 7.1 speakers with a PBR 300x2 amp.
I haven't had any speaker issues yet.
If your speakers are actually blown, I would suggest you call Biketronics, I believe those speakers have a lifetime warranty.
Call Biketronics... I had an issue where the do-hicky that is soldered from one pin to another broke and well as the mounting ring broke. They replaced under warranty.
I've had a few small not worth mentioning issues along the way. No worries with Biketronics there top notch all the way and have exceeded my expectations in handling my issues every time.
