Speaker wiring
Old Jun 9, 2015 | 12:09 PM
BuzzL's Avatar
BuzzL
Default Speaker wiring
What is the best way to wire the two pod speakers into my system? I have a 4 channel amp running a pair of lid speakers and a pair of fairing speakers. I would like to splice in the tour pack speakers and when I remove the tour pak the speakers would disconnect at the stock plugs under the seat. Where and what wiring sequence would be best? This is a 4 ohm amp. Thanks for any help.
Old Jun 9, 2015 | 03:00 PM
Gannicus's Avatar
Gannicus
1. Is the amp two and 4 ohm compatible?
2. Are all the speakers 4 ohm?
If it's the set up you have in your signature. You are running all two ohm speakers and won't have the ability to run an extra set in parallel.
Old Jun 9, 2015 | 05:29 PM
BuzzL's Avatar
BuzzL
Thanks Gannicus
Old Jun 9, 2015 | 06:48 PM
TinmanToledo's Avatar
TinmanToledo
6th Gear
I run the stock tour pak speakers off the factory HU, I have the same setup, 1 amp lid speakers, 1 amp fairing. tour pak is plug & play
SgtMic
Audio Systems
13
Feb 15, 2017 03:06 AM
GNR
Audio Systems
Jan 24, 2015 03:40 PM
BuzzL
Audio Systems
14
Sep 1, 2014 03:42 PM
Brew61
Audio Systems
21
Apr 8, 2014 08:18 AM
Coolhawg6622
May 15, 2011 09:05 PM
