Radio gets distorted on Acceleration
Old Aug 11, 2015 | 10:58 AM
LAMA ORLANDO's Avatar
LAMA ORLANDO
Default Radio gets distorted on Acceleration
My radio on my 09 Ultra get distorted during acceleration and then returns to normal on cruising speed. I have a Hogtunes 2.1 amp and speakers with the speaker pod. All connections look good - is this an radio issue? Any ideas or help are greatly appreciated.
Old Aug 11, 2015 | 12:00 PM
Gannicus's Avatar
Gannicus
Sounds like an issue with the amp and or the battery. The only thing that happens when you accelerate is more juice to the battery. While cruising your battery should be reading 14V at all times. Stopped it will drop down to 12.5 with the music on. As you increase speed it should come back up to 14V. If your battery is doing those two things your system is performing correctly. If not there is an issue with your charging system. I'd make sure the charging system is operating correctly first.
Old Aug 11, 2015 | 12:16 PM
AAWAV's Avatar
AAWAV
sure you are not mixing up your exhaust pipe sound with music LOL?
Old Aug 11, 2015 | 01:39 PM
SBates08's Avatar
SBates08
Make sure your AVC is turned off on the HU as well.
2010 Limited with some stuff
Old Aug 11, 2015 | 03:22 PM
just plain john's Avatar
just plain john
^^^^This.
Old Aug 11, 2015 | 03:25 PM
1BRAVO9's Avatar
1BRAVO9
Could it be a bad ground??
Old Aug 11, 2015 | 03:30 PM
just plain john
Hard to say, but all things audio rely on clean power, where 12v is constant. Is it grounded directly to the battery? Did you check to see that the AVC is off?
Old Aug 11, 2015 | 05:35 PM
Gannicus's Avatar
Gannicus
lol.... All the above!
Old Aug 11, 2015 | 07:33 PM
tdgriff's Avatar
tdgriff
<p>You guy kill me . AVC That seems to easy lol</p>
Old Aug 11, 2015 | 09:20 PM
SBates08's Avatar
SBates08
True.....but you never know.
