Which Amp Is Better And Why??
Old Aug 13, 2015 | 01:33 AM
badazzpred's Avatar
badazzpred
Default Which Amp Is Better And Why??
SS PN4.1000D
PA RZ4-3000D
Looking to upgrade from my current amp the SS PN4.520D
Old Aug 13, 2015 | 05:24 AM
just plain john's Avatar
just plain john
Essentially they are the same amp, made by the same manufacturer. Everyone says they will fit, but both are slightly longer than your 520. I just ordered the PA amp yesterday because it's a few bucks cheaper.
Old Aug 13, 2015 | 09:03 AM
Gannicus's Avatar
Gannicus
Same amp. Both are very powerful amps pushing about 140 watts RMS @ 4 ohms. Just branded differently. Both fit in the fairing. Tight but they fit. If you purchase the PA you will have to take off the handles for it to fit.
Old Aug 13, 2015 | 09:33 AM
badazzpred's Avatar
badazzpred
But I guess my main ? is if it holds true to spec? Is that according to actual specs the PA RZ4 2000D & 3000D are a much higher RMS rating at 4 ohms than the SS PN4.1000D does this hold true? and or is either one better being a cleaner slash no distortion sound?
Thanks
Old Aug 13, 2015 | 09:45 AM
AAWAV's Avatar
AAWAV
I have done bench tests, in the sticky.
Comments regarding specs are there as well...
PA amps specs are highly overrated, SS is pretty much on spec.
Hence think about PA as SS (brother and sister amps). Never opened them but pretty much sure they are identical on the inside.
https://www.hdforums.com/forum/audio...ch-6-amps.html
Old Aug 13, 2015 | 10:07 AM
austinslider's Avatar
austinslider
I have the SS 4.1000 and it's a great little amp. I was able to pick it up on Ebay for $159.00.
Old Aug 13, 2015 | 10:17 AM
AAWAV's Avatar
AAWAV
Little????? LOL
Old Aug 13, 2015 | 11:00 AM
Gannicus's Avatar
Gannicus
Only pay attention to AAWAV'S Specs. Not to worry BadAzz. Both amps have been tested and vetted by myself AAWAV and HAZE. For lack of a better term they are BOTH Bad Azz amps!! Buy it brother!!
Old Aug 13, 2015 | 02:18 PM
austinslider
Originally Posted by AAWAV
Little????? LOL
Where I come from, it's considered little...lol.
Old Aug 13, 2015 | 04:48 PM
AAWAV's Avatar
AAWAV
now I can make a comment but need to keep in mind this forum is publicly accessible by kids < 16 yrs LMAO.
it is still small in general for the power, but big for our rides....
