Bass and Treble control lost with flash
Old Sep 21, 2015 | 08:47 AM
barrygreen's Avatar
barrygreen
Default Bass and Treble control lost with flash
Anyone have a answer to this?
Had the bike flashed per BT 1 amp 2 fairing speakers (128 off), the bass and treble control is there, moves but has no affect on sound.
Old Sep 21, 2015 | 03:00 PM
Beldar's Avatar
Beldar
Welcome to the group (2 fairing BT speakers and mounts, BT amp, latest flash, 128 off bin file along with no functioning AVC). Still surprising how well it sounds.
Had my 10,000 mile checkup & service last week and I informed the service department of this problem. Currently, they have no answers, even acknowledging there are problems with the Boom components also.
However, the diagnostic codes did indicate a supposed malfunctioning head unit (which other than the stuff noted above, all else is good). They indicated that at my next service it will be checked again and if present will probably file a warranty claim for a new one.
Old Sep 24, 2015 | 10:11 AM
CaptainKirk's Avatar
CaptainKirk
Lost mine with a Rockford Fosgate recommended flash, too. It will make a VERY small difference between min and max but it essentially sets everything flat. I'm finding my Infinity Kappa's are really bright but overall I'm satisfied with the setup and loss of adjustment. I usually run my settings flat anyway......
Old Sep 24, 2015 | 12:18 PM
barrygreen's Avatar
barrygreen
Well I am waiting for the BT amp to arrive and we will see ...
This is a reply I received from BT about the flash I have now:
Unlike the auto sound industry Harley puts a big juicy spike in the mid base region to get some mid base out of them. This spike is like 14db up from reference. So, when you turn our stuff up with WAY more power behind the speaker, it gets really distorted really fast. So, you are correct the flash is to correct this, flattening out the sound curve.
Our amp will make up for everything else, provided the input is nice and clean and flat. The SNI-35 may need to have the gain increased to make up for radio flash not only flattening out the sound curve but also, likely dropping the reference voltage down. This is a good thing because it gets you out of the distorted threshold that Harley would rather run the radio to get louder. Their less sensitive speakers and amps will not accurately portray this distortion. And, generally will not get as loud or sound nearly as good.
If you can handle not having the eq, then our setup should work great. Please keep us posted and thank you for your input.
tylerfj24
Audio Systems
Jul 19, 2018 12:31 AM
dab102999
Audio Systems
May 1, 2018 08:43 AM
twinchrome
Audio Systems
26
Jul 20, 2017 08:53 PM
pjim
2014-2024 Touring Models
25
Aug 17, 2015 06:56 PM
big TYME
Aug 22, 2014 04:46 PM
