fix for loose volume button?
Old Oct 16, 2015 | 04:33 PM
nineball's Avatar
nineball
Default fix for loose volume button?
on my new hu anytime the volume is changed it displays it on the screen and over rides the clock display. my volume button has become loose to the point of any decent bump in the road and it changes the volume by 1 or 2 clicks, which causes my screen to change and draws my eyes down. anyone know of a fix for this or am i destined to buy a new switch?
Old Oct 16, 2015 | 05:28 PM
FLYINGBROKE's Avatar
FLYINGBROKE
maybe some fresh dielectric grease / o ring some where to add some resistance. no idea just board sorry to waste your time.
Old Oct 16, 2015 | 05:48 PM
SBates08's Avatar
SBates08
Sounds like your switch is really close to failing all together. You can replace it yourself if your handy with a soldering iron.
2010 Limited with some stuff
Old Oct 17, 2015 | 09:03 AM
Roadie13's Avatar
Roadie13
Are you sure it's the switch and not AVC? Mine did the same thing and hated it. Turned the avc off and not an issue.
Old Oct 17, 2015 | 09:11 AM
nineball's Avatar
nineball
Can't be AVC. The new hu doesn't have it. It's the switch.
Old Oct 18, 2015 | 05:15 PM
09baggerdude's Avatar
09baggerdude
Default Avc
AVC has nothing to do with the hu. Its possible to keep with the biketronics kit only.
Old Oct 18, 2015 | 05:20 PM
nineball's Avatar
nineball
Well that's a first for me. I've never seen an AVC system work with an aftermarket hu.
Regardless that is not the problem as it happens on bumps, not changes in speed. Since it doesn't seem to be a too common of a problem I'll just order a new switch and add it to the winter list of things to do.
Petiej
Electrical/Lighting/Alarm
Aug 21, 2019 06:12 AM
tinsnips
Sep 22, 2016 04:49 PM
lhgdale
Jun 15, 2016 08:55 AM
cnnesseth
Mar 2, 2015 05:01 PM
Primetime_2
Apr 23, 2014 11:09 AM
