Adding a second amp with no rca inputs
Old Oct 23, 2015 | 10:37 AM
Aero993's Avatar
Aero993
Default Adding a second amp with no rca inputs
I'm thinking about add a second pn4.1000d to my system. Question since the first amp was installed using line-in (no rca) how would I connect the second amp to the radio? I'm thinking about doing the upgrade myself.
Thanks
Old Oct 23, 2015 | 10:44 AM
haze324's Avatar
haze324
1. try connecting the rear speaker wires to your harness.
2. You can most likely use the same wires you are using now with no ability to fade
3. If you want to use RCA's you can use hi-lo RCA converter and then run a splitter, again no fade ability.
harleync
Audio Systems
67
Mar 4, 2017 11:52 PM
No U Glider
Audio Systems
Oct 5, 2016 04:31 PM
BigWaterJim
Audio Systems
Aug 14, 2016 09:58 AM
nebraider
Audio Systems
Dec 24, 2015 02:36 PM
Mirnldi@gmail.com
Audio Systems
Jul 23, 2014 01:38 PM
