2012 SG - USB stick
Old Dec 11, 2015 | 11:48 AM
Herbkell's Avatar
Herbkell
Default 2012 SG - USB stick
I was hoping to be able to play music from a USB stick (thumb drive) through the Aux port.
I bought a cheap USB to male 3.5mm cable and tried but no go. Am I missing something or is this just not possible?
USB stick plays fine in my car
Thanks
Old Dec 11, 2015 | 03:03 PM
Hades02's Avatar
Hades02
Are you using the same setup in the car (usb to male 3.5mm cable? Most stock car radios these days have the ability to read thumb drives. Old units do not. That may be your issue.
Old Dec 11, 2015 | 03:46 PM
Herbkell's Avatar
Herbkell
My car has a female usb input built into the console between the seats
Old Dec 12, 2015 | 06:54 AM
Hades02's Avatar
Hades02
That's why it plays in your car. I'm sure if you tried using the aux input via the 3.5mm plug you would get the same results as on the bike.
one sends unprocessed digital data to the head unit (USB), and the other one sends a processed, analog audio signal (3.5mm). It may be easier to think of it as the USB cable transferring data, like you would to a computer, and the aux cable transferring an audio signal, like you would to your earbuds. So because the USB stick is not processed it needs to be processed by software in the deck which the stock head unit does not have.
Time to swap out your head unit. $109 on Amazon and Ebay for the Sony 310BTX. Great deck at that price.
Old Dec 12, 2015 | 08:38 AM
AAWAV's Avatar
AAWAV
correct - stocker HU (2013-and older) is not able to play mp4 from usb tick (from CD it does for the more recent models up to 2013, but PITA in my opinion to burn a good working. audio aux input you can use to put in your phone or ipod/mp3 player
Old Dec 12, 2015 | 11:25 AM
Herbkell's Avatar
Herbkell
Thanks guys your explanations makes sense
I will continue to use my phone and forget the usb stick
58sniper
2014-2024 Touring Models
Sep 16, 2015 11:41 PM
Rockrivr1
29
Aug 4, 2014 07:09 PM
dougyf
Oct 3, 2013 10:39 PM
ssmith579
Apr 4, 2012 10:17 AM
larry5h
Jul 24, 2007 12:15 PM
