Why would you want to run 2 amps?
That alpine amp only specs out at 50w rms at 4 ohms and 75w at 2 ohm.
I would suggest getting a different amp (4 channel ) that is 2 or 4 ohm compatible.and only use the one amp instead of running 2 different amps.
The Soundstream pn4-1000d would take care of that issue
This amp is 140w at 4 ohms and 250w at 2 ohm per channel and should be plenty of power for the speakers you have.
I know it pushes the KAPPAS real good at 2 ohm
So far following the advice and research I have found on this forum I have purchased and sold (at a loss) many components already. Isn't there anyone that can help me utilize the amps and speakers I have already purchased?
As originally stated I believe I was told to BRIDGE the Kenwood amp to power the AB speakers to get the power I need.
You can run the 2 speaker outputs from the HU to line converter on 1 channel and use a "y" rca splitter to the 2 amps or tie the 2 left channels together and the same for the right on the input side of the line leveler and use all 4 rca output on line leveler to amp
Ok so I have this straight. I take the front outputs from the HK...FNT RT +&-
and FNT LT + & - and wire them to the inputs of the line leveler but wire all 8 wires going into the leveler to the 4 coming from the fnt output of the HK? Then use all four RCA from the leveler to bridge the Kenwood amp?
Then take the HK Rear RT +&- and Rear LT +& - and wire them to the RF amp?
So you are saying you have front and rear channels on your HU?
IF that is the case are the rear channels active(working)? If they are active you can take each speakers output (4)and wire it to the LL. (One speaker to one input on LL)If the rears are not active then just use the front channel as discussed earlier
I have all 8 outputs from the HK but I don't know for sure if they are active or not. I can check that easy enough. If not I can have HD activate them for me? I thought they were active but HK has to be reflashed to activate the fader.
Either way I am still confused on the wiring to the line leveler/Kenwood amp and also the RF amp. Remember I want to bridge the kenwood amp to get the necessary power for the AB speakers. RF amp powers the Infinity speakers
