istall questions
Old Dec 30, 2015 | 07:51 AM
wils5150's Avatar
wils5150
Default istall questions
Do you guys tin your wires? if so how much solder do you put on? Any tips on removing the stock head unit on a 13 road glide? I am curious on if the head unit comes out towards the front or towards the seat.
Thanks *****
Old Dec 30, 2015 | 08:15 AM
Gannicus's Avatar
Gannicus
Yeah most of us tin the wires. Just enough solder to keep the wires from fraying.
***** get yourself a 3/8 drive long ball head hex socket set. You will be using the 3/16 socket out of the set. It makes life a whole lot easier getting to the stock radio bolts. After you get the four bolts out you will pull the radio out from the front. Start by pushing it from the back until you can grab it from the front.
Old Dec 30, 2015 | 10:18 AM
TcHunter's Avatar
TcHunter
Thanks *****
My rule has always been when soldering two wires together I use just enough to hold tight but not to much where I need to fight with the shrink tube. You don't need much and the shrink tube should slide right over as if it was one wire.
Old Dec 30, 2015 | 12:19 PM
Roadie13's Avatar
Roadie13
Assuming you're pulling the stocker to install an aftermarket HU, there's a few tricks that can help the install as well.
I installed a kenwood with the BT retro kit and found a great shortcut for RG - the directions have you loosen the 4 nuts for the main radio mounting bracket and then flex the fairing to install the radio from the headlight side. Scared the crap out of me, couldn't believe the fairing didn't crack trying to squeeze the HU in. Instead of that, the backing plate for the install kit and the trim plate for the stereo will easily slide in the faceplate opening (from the gas tank side) and the stereo itself will then slide in from the headlight slide. It's kind of a pain to get the backing plate and trim plate back on, but nowhere near as difficult as screwing with the radio/bracket and flexing the fairing. Way easier and less frustrating for sure. Good luck......
Old Dec 30, 2015 | 01:02 PM
Babyboy's Avatar
Babyboy
If you don't want to solder/tin the wires and you have screw terminals you can use non-insulated but connectors
12- 16 guage for speaker and 10-12 guage for your power wires.
Old Dec 30, 2015 | 04:01 PM
wils5150's Avatar
wils5150
never thought of those. pretty secure using those?
Old Dec 30, 2015 | 04:05 PM
Babyboy's Avatar
Babyboy
Here is how I did mine
Terminals were close on speaker wires so I put heat shrink on them
Old Dec 30, 2015 | 04:13 PM
wils5150's Avatar
wils5150
thanks I will look into those. I take it you crimp them first and the screw just bites in to them.
Old Dec 30, 2015 | 07:03 PM
Babyboy's Avatar
Babyboy
Yeppers that's it.If you can't find the non-insulated you can use the insulated ones and just make a slice down the side and push it out
FLHTK2015
Audio Systems
Jun 15, 2019 08:27 PM
TcHunter
Audio Systems
Jan 5, 2016 07:24 PM
Roadie13
Audio Systems
Aug 22, 2015 05:01 PM
kyote
Feb 26, 2013 12:20 PM
Storm_law
May 20, 2010 07:22 PM
